Hi there!
I would like to build a small "PLC Hacking Demo" using an Arduino, an air pump and a balloon.
This is the scenario: I have a workstation where I can control the PLC (aka Arduino) to inflate a balloon until it reaches a normal size. The arduino and the pump/compressor should be programmable so I can enter a PSI value for the normal size and the pump stops. It should also be able to show me current value (electronically on a display). The "bad hacker" then hacks the workstation, changes the psi value while the display shows a false value. The balloon explodes ![]()
So this is basically a very, very boring version of "Stuxnet" ![]()
I need your guidance on the parts you would recommend for this project. I'm having particular difficulties to find a suitable pump that is small enough to be transported from demo site to demo site. I looked at several 12v compressors but they are to large, heavy and can't show/set the air pressure precise enough.
