How do you know the transmission works, if you haven't received it to see what it is?
To use a receiver like that TSOP you need to create a carrier signal flashing at 38kHz and then, modulate that signal with the message you want to send.
That message could simply just be an on and an off, or a number of flashes, in which case you could read that with just a digitalRead.
You could use the VirtualWire library for one way transmission or SoftSerial for two way with an RX/TX pair at each end. One problem you'll see is ambient IR background from other sources. Device aiming and shielding will solve that to some degree.
Arctic_Eddie:
Using a 38kHz TSOP, where a 38k carrier is modulated by the actual message, reputedly takes a lot of that problem away. I guess it's unlikely that stray IR will be a modulated 38kHz signal.
If you are using that TSOP receiver, you need to send it a modulated signal. That is, a 38kHz carrier, modulated by the "message" you want to send.
The TSOP is an active low device, it will output a high, the 1 you are getting, under all circumstances except when it's getting a 38kHz carrier at which point it will go low.
So the TSOP is working correctly right now: if you power the TSOP and send it a solid IR or no IR, it will still give a high. Your 1000ms blink from your transmitter, although it's working in the sense you can see the IR through your camear, is not working as far as the TSOP receiver is concerned. It needs a 38kHz carrier, not a "solid on".
So look further into my write-up and you'll see a few ways to do that. Easiest is to use tone()and if I recall there's an example of that code in there. In the presence of a 38kHz stream from that tone() code, the TSOP should go low.
So how do you send a message over to the ir led. I like to send a command of "/?!" Over a 38kHz modulated ir led.
So while modulating sending some command.
Can you help me with that part?
