INPUT_PULLUP explanation
const int richtingPin = 8;
const int stappenPin = 7;
const int knoplinksdraaien = A0;
const int knoprechtsdraaien = A1;
const int knopuit = A2;
void setup(){
pinMode(richtingPin,OUTPUT);
pinMode(stappenPin,OUTPUT);
pinMode(knoplinksdraaien,INPUT_PULLUP);
pinMode(knoprechtsdraaien,INPUT_PULLUP);
pinMode(knopuit,INPUT_PULLUP);
stepRechts(false,32000);
void loop (){
if(digitalRead(knoprechtsdraaien)==LOW){
Serial.println("rechter knop ingedrukt");
stepLinks(false,48);
if(digitalRead(knoplinksdraaien)==LOW){
Serial.println("linker knop ingedrukt");
stepRechts(true,48);
void stepLinks(boolean richting,int aantalstappen){
digitalWrite(richtingPin,richting);
delay(50);
for(int i=0;i<aantalstappen;i++){
Serial.println(i);
if(digitalRead(knopuit)==LOW){
Serial.println("stop knop");
digitalWrite(stappenPin,HIGH);
delayMicroseconds(1200);
digitalWrite(stappenPin,LOW);
void stepRechts(boolean richting,int aantalstappen){
delay(50);
Serial.println(i);
Do you have a question?
Code tags?
You have two virtually absolutely identical functions. Why?
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
INPUT_PULLUP holds the pin at Vcc so it is not in an unknown state between Vcc and GND. When your button is not pressed, it reads HIGH. When you press your button, the pin is then connected through the button to ground, where the pin then reads LOW.
const int richtingPin = 8; // DIRECTION PIN
const int stappenPin = 7; // STEP PIN
const int knoplinksdraaien = A0; // LEFT TURN BUTTON
const int knoprechtsdraaien = A1; // RIGHT TURN BUTTON
const int knopuit = A2; // STOP BUTTON
  pinMode(richtingPin, OUTPUT);
  pinMode(stappenPin, OUTPUT);
  pinMode(knoplinksdraaien, INPUT_PULLUP); // NOTPRESSED = HIGH and PRESSED = LOW
  pinMode(knoprechtsdraaien, INPUT_PULLUP); // NOTPRESSED = HIGH and PRESSED = LOW
  pinMode(knopuit, INPUT_PULLUP); // NOTPRESSED = HIGH and PRESSED = LOW
  stepRechts(false, 32000);
void loop () {
  if (digitalRead(knoprechtsdraaien) == LOW) { // IF PRESSED (IF LOW)
    Serial.println("rechter knop ingedrukt"); // RIGHT TURN BUTTON PRESSED
    stepLinks(false, 48);
  if (digitalRead(knoplinksdraaien) == LOW) { // IF PRESSED (IF LOW)
    Serial.println("linker knop ingedrukt"); // LEFT TURN BUTTON PRESSED
    stepRechts(true, 48);
void stepLinks(boolean richting, int aantalstappen) { // STEP LEFT (DIRECTION, NUMBER OF STEPS)
  digitalWrite(richtingPin, richting); // COUNTER-CLOCKWISE
  delay(50);
  for (int i = 0; i < aantalstappen; i++) {
    Serial.println(i);
    if (digitalRead(knopuit) == LOW) {
    digitalWrite(stappenPin, HIGH);
    digitalWrite(stappenPin, LOW);
void stepRechts(boolean richting, int aantalstappen) { // STEP RIGHT (DIRECTION, NUMBER OF STEPS)
  digitalWrite(richtingPin, richting); // CLOCKWISE
  delay(50);
    Serial.println(i);
