Ok, ca marche mieux.
Je suis avec Ubuntu sur mon PC, j'ai IDE Arduino version 2.3.4
J'ai telecharger le .ino là où ton lien dit qu'il y est, ca donne cela
/*mini radar kit*/
#include <Servo.h>
#include <SPI.h>
#include "Ucglib.h"
#define trigPin 6 //Ultrasonic Module Trig->D6
#define echoPin 5 //Ultrasonic Module Echo->D5
#define ServoPin 3 //Servo Signal->D3
int Ymax = 128; //vertical pixels of the screen
int Xmax = 160; //horizontal pixels of the screen
int Xcent = Xmax / 2; //Horizontal screen center position
int base = 118; //baseline position
int scanline = 105; //Radar scan line length
Servo baseServo;
Ucglib_ST7735_18x128x160_HWSPI ucg(/*cd=*/ 9, /*cs=*/ 10, /*reset=*/ 8);
void setup(void)
ucg.begin(UCG_FONT_MODE_SOLID); //initialization screen
ucg.setRotate90(); //Set to horizontal screen If the screen display direction is reversed, you can modify the function setRotate90 or setRotate270
pinMode(trigPin, OUTPUT); //Set the trig Pin port mode
pinMode(echoPin, INPUT); //Set echo Pin port mode
Serial.begin(115200); //Set the serial port transmission rate
baseServo.attach(ServoPin); //Initialize servos
//screen startup interface
ucg.setFontMode(UCG_FONT_MODE_TRANSPARENT);
ucg.setColor(0, 0, 100, 0);
ucg.setColor(1, 0, 100, 0);
ucg.setColor(2, 20, 20,20);
ucg.setColor(3, 20, 20, 20);
ucg.drawGradientBox(0, 0, 160, 128);
ucg.setPrintDir(0);
ucg.setColor(0, 5, 0);
ucg.setPrintPos(27,42);
ucg.setFont(ucg_font_logisoso18_tf);
ucg.print("Mini Radar");
ucg.setColor(0, 255, 0);
ucg.setPrintPos(25,40);
ucg.setFont(ucg_font_helvB08_tf);
ucg.setPrintPos(40,100);
ucg.print("Testing...");
baseServo.write(90);
//Test the operation of the base, pay attention to the position and rotation posture of the base, and whether there is any jamming (or wire winding).
for(int x=0;x<180;x+=5)
{ baseServo.write(x);
delay(50);
ucg.print("OK!");
ucg.setColor(0, 0, 0, 0);
ucg.setColor(1, 0, 0, 0);
ucg.setColor(2, 0, 0,0);
ucg.setColor(3, 0, 0, 0);
//clear screen
//ucg.clearScreen();
cls();
ucg.setFont(ucg_font_orgv01_hr);
ucg.setFontMode(UCG_FONT_MODE_SOLID);
void cls()
//clear screen
for(int s=0;s<128;s+=8)
for(int t=0;t<160;t+=16)
ucg.drawBox(t,s,16,8);
// delay(1);
int calculateDistance()
long duration;
//power off trigPin and wait 2 microseconds
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
//TrigPin power on delay 10 microseconds and then power off
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
//Reading the echoPin returns the travel time of the sound wave (in microseconds)
duration = pulseIn(echoPin, HIGH);
//Convert echo time to distance value
return duration*0.034/2;
void fix_font()
ucg.setColor(0, 180, 0);
ucg.setPrintPos(70,128-120+7);
ucg.print("100cm");
ucg.setPrintPos(70,128-85-11);
ucg.print("75cm");
ucg.setPrintPos(70,128-60-8);
ucg.print("50cm");
ucg.setPrintPos(70,128-35-4);
ucg.print("25cm");
void fix()
ucg.setColor(0, 40, 0);
//Draw a background image
ucg.drawDisc(Xcent, base+1, 3, UCG_DRAW_ALL);
ucg.drawCircle(Xcent, base+1, 115, UCG_DRAW_UPPER_LEFT);
ucg.drawCircle(Xcent, base+1, 115, UCG_DRAW_UPPER_RIGHT);
ucg.drawCircle(Xcent, base+1, 86, UCG_DRAW_UPPER_LEFT);
ucg.drawCircle(Xcent, base+1, 86, UCG_DRAW_UPPER_RIGHT);
ucg.drawCircle(Xcent, base+1, 58, UCG_DRAW_UPPER_LEFT);
ucg.drawCircle(Xcent, base+1, 58, UCG_DRAW_UPPER_RIGHT);
ucg.drawCircle(Xcent, base+1, 29, UCG_DRAW_UPPER_LEFT);
ucg.drawCircle(Xcent, base+1, 29, UCG_DRAW_UPPER_RIGHT);
ucg.drawLine(0, base+1, Xmax,base+1);
ucg.setColor(0, 120, 0);
//draw scale
for(int i= 40;i < 140; i+=2)
if (i % 10 == 0)
ucg.drawLine(105*cos(radians(i))+Xcent,base - 105*sin(radians(i)) , 113*cos(radians(i))+Xcent,base - 113*sin(radians(i)));
ucg.drawLine(110*cos(radians(i))+Xcent,base - 110*sin(radians(i)) , 113*cos(radians(i))+Xcent,base - 113*sin(radians(i)));
//draw some decorative patterns
ucg.setColor(0,200,0);
ucg.drawLine(0,0,0,18);
for(int i= 0;i < 5; i++)
ucg.setColor(random(255),random(255),random(255));
ucg.drawBox(2,i*4,random(14)+2,3);
ucg.setColor(0,0,180);
ucg.drawFrame(146,0,14,14);
ucg.setColor(0,0,60);
ucg.drawHLine(148,0,10);
ucg.drawVLine(146,2,10);
ucg.drawHLine(148,13,10);
ucg.drawVLine(159,2,10);
//ucg.setColor(0,220,0);
ucg.drawBox(148,2,4,4);
ucg.drawBox(148,8,4,4);
//ucg.setColor(100,0,0);
ucg.drawBox(154,8,4,4);
//ucg.setColor(0,0,150);
ucg.drawBox(154,2,4,4);
ucg.setColor(0,0,90);
ucg.drawTetragon(62,123,58,127,98,127,102,123);
ucg.setColor(0,0,160);
ucg.drawTetragon(67,123,63,127,93,127,97,123);
ucg.setColor(0,255,0);
ucg.drawTetragon(72,123,68,127,88,127,92,123);
void loop(void)
int distance;
fix();
fix_font(); //Repaint screen background elements
for (int x=180; x > 4; x-=2){ //The base servo rotates from 180 to 0 degrees
baseServo.write(x); //Adjust the steering gear angle
//Draw Radar Scanlines
int f = x - 4;
ucg.drawLine(Xcent, base, scanline*cos(radians(f))+Xcent,base - scanline*sin(radians(f)));
f+=2;
ucg.setColor(0, 128, 0);
f+=2;
ucg.setColor(0, 0, 0);
ucg.setColor(0,200, 0);
//Get the distance value
distance = calculateDistance();
//Draw a point at the corresponding position according to the measured distance
if (distance < 100)
ucg.setColor(255,0,0);
ucg.drawDisc(1.15*distance*cos(radians(x))+Xcent,-(1.15*distance*sin(radians(x)))+base, 1, UCG_DRAW_ALL);
{ //If it is more than 1 meter, it is indicated by a yellow painting on the edge area
ucg.setColor(255,255,0);
ucg.drawDisc(116*cos(radians(x))+Xcent,-116*sin(radians(x))+base, 1, UCG_DRAW_ALL);
//Debug code, output angle and range value
Serial.print("Degree: ");
Serial.print(x);
Serial.print(" ,Distance: ");
Serial.println(distance);
if (x > 70 and x < 110) fix_font(); //When the scan line and the number coincide, redraw the number
ucg.setColor(0,0,155, 0);
ucg.setPrintPos(0,126);
ucg.print("DEG: ");
ucg.setPrintPos(24,126);
ucg.print(x);
ucg.print(" ");
ucg.setPrintPos(125,126);
ucg.print(" ");
ucg.print(distance);
ucg.print("cm ");
delay(50);
cls();
fix();
for (int x=1; x < 176; x+=2){
int f = x + 4;
f-=2;
f-=2;
ucg.setColor(0, 200, 0);
//测距
if (distance < 100)
Serial.print(x);
ucg.print("DEG: ");
ucg.print(x);
ucg.print(" ");
ucg.print(" ");
ucg.print("cm ");
delay(50);
cls();
J'ai telechargé les bibliothéque qui n'étaient pas installées chez moi, c.à.d Ucglib.h, j'ai téléversé le programme sur mon UNO, et je n'ai pas eut d'erreur
N'ayant que un UNO et pas le Kit radar, je ne peux pas aller plus loin!
