Install Arduino 2.0
Hello,
I trying to install the 2.0 version of the IDE
I'm under linux debian buster.
I have unzipped the file.
But when i want to start the ide in a terminal the answer is
$ sudo ./arduino-ide
[11524:0128/111830.648415:FATAL:electron_main_delegate.cc(254)] Running as root without --no-sandbox is not supported. See 638180 - chromium - An open-source project to help move the web forward. - Monorail.
Trappe pour point d'arrêt et de trace
I have changed the owner of the directory of arduino2.0, put the mode of chrome-sandbox to 755, but answer still te same.
Anyone a idea to go further ??
Thank you
Michel
You can take a look at https://docs.arduino.cc/software/ide-v2/tutorials/getting-started/ide-v2-downloading-and-installing
Where? Somewhere in your home directory?
Do you need sudo?
Hello,
For dozie,
Ihave followed the tuto to install the ide, but no information about the problem.
for Sterretje,
So I have unzipped in the /home/miche/download in first time
then I have move the full directory in the /home/michel/arduino-ide_2.0.0-rc3_Linux_64bit
I have change the owner to "root". no effect
I have change the mode to 755 (what is 4755 ???? in the error message)
I have try with sudo ./arduino-ide, but error change, I give the error message in my first post
the answer to ./arduino-ide is :
$ ./arduino-ide
[4137:0129/083110.589068:FATAL:setuid_sandbox_host.cc(158)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /home/michel/arduino-ide_2.0.0-rc3_Linux_64bit/chrome-sandbox is owned by root and has mode 4755.
I start my command in the ~/arduino-ide_2.0.0-rc3_Linux_64bit$ directory
this the ls -l of my directory:
~/arduino-ide_2.0.0-rc3_Linux_64bit$ ls -l
total 175768
-rwxrwxrwx 1 root michel 127574984 déc 22 16:53 arduino-ide
-rw-rw-rw- 1 root michel 179981 déc 22 16:52 chrome_100_percent.pak
-rw-rw-rw- 1 root michel 321151 déc 22 16:52 chrome_200_percent.pak
-rwxr-xr-x 1 root michel 6322128 déc 22 16:52 chrome-sandbox
-rw-rw-rw- 1 root michel 10505952 déc 22 16:52 icudtl.dat
-rwxrwxrwx 1 root michel 243992 déc 22 16:52 libEGL.so
-rwxrwxrwx 1 root michel 3103488 déc 22 16:52 libffmpeg.so
-rwxrwxrwx 1 root michel 8948976 déc 22 16:52 libGLESv2.so
-rwxrwxrwx 1 root michel 4488304 déc 22 16:52 libvk_swiftshader.so
-rwxrwxrwx 1 root michel 8483376 déc 22 16:52 libvulkan.so
-rw-rw-rw- 1 root michel 1060 déc 22 16:52 LICENSE.electron.txt
-rw-rw-rw- 1 root michel 4710103 déc 22 16:52 LICENSES.chromium.html
drwxrwxrwx 2 root michel 4096 déc 22 16:52 locales
drwxrwxrwx 3 root michel 4096 déc 22 16:53 resources
-rw-rw-rw- 1 root michel 4835574 déc 22 16:52 resources.pak
-rw-rw-rw- 1 root michel 50591 déc 22 16:52 snapshot_blob.bin
drwxrwxrwx 2 root michel 4096 déc 22 16:52 swiftshader
-rw-rw-rw- 1 root michel 170904 déc 22 16:52 v8_context_snapshot.bin
-rw-rw-rw- 1 root michel 107 déc 22 16:52 vk_swiftshader_icd.json
thank you
michel
linux file permissions 4755 - Google Search :wink:
My Linux knowledge nowadays hardly exists so you will have to analyse further.
You have satisfied the first requirement but I don't think that you satisfied the second one. Some more to read: linux setuid - Google Search :wink:
Hello,
I have erase all te directory...
I have unzipped in a "arduino-2.0" easy to write on terminal :slight_smile:
I have put the owner group to root for the full directoy.
I have set the right to 4755 for all the directoy.
Now the message is
~/arduino-2.0$ ./arduino-ide
The setuid sandbox is not running as root. Common causes:
  • An unprivileged process using ptrace on it, like a debugger.
  • A parent process set prctl(PR_SET_NO_NEW_PRIVS, ...)
    Failed to move to new namespace: PID namespaces supported, Network namespace supported, but failed: errno = Operation not permitted
A progress, but.......
I have also try with su to launch the arduino-ide, but same answer...
thanks
michel
