Hello,
The esp32 board list is huge and I just use like one. ![]()
Is there a way to make it shorter? I know boards.txt for AVR, but I can't seem to find similar for esp.
Thanks in advance.
Hello,
Take a look in the Arduino15 folder
C:\Users<username>\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\boards.txt
Ohh how did I miss this?! :S
So I could just delete the unnecessary sections, right? E.g. Pico Kit with it's separator:
pico32.name=ESP32 Pico Kit
pico32.upload.tool=esptool_py
pico32.upload.maximum_size=1310720
pico32.upload.maximum_data_size=327680
pico32.upload.wait_for_upload_port=true
pico32.serial.disableDTR=true
pico32.serial.disableRTS=true
pico32.build.mcu=esp32
pico32.build.core=esp32
pico32.build.variant=pico32
pico32.build.board=ESP32_PICO
pico32.build.f_cpu=240000000L
pico32.build.flash_size=4MB
pico32.build.flash_freq=80m
pico32.build.flash_mode=dio
pico32.build.boot=dio
pico32.build.partitions=default
pico32.build.defines=
pico32.menu.PartitionScheme.default=Default
pico32.menu.PartitionScheme.default.build.partitions=default
pico32.menu.PartitionScheme.no_ota=No OTA (Large APP)
pico32.menu.PartitionScheme.no_ota.build.partitions=no_ota
pico32.menu.PartitionScheme.no_ota.upload.maximum_size=2097152
pico32.menu.PartitionScheme.min_spiffs=Minimal SPIFFS (Large APPS with OTA)
pico32.menu.PartitionScheme.min_spiffs.build.partitions=min_spiffs
pico32.menu.PartitionScheme.min_spiffs.upload.maximum_size=1966080
pico32.menu.UploadSpeed.921600=921600
pico32.menu.UploadSpeed.921600.upload.speed=921600
pico32.menu.UploadSpeed.115200=115200
pico32.menu.UploadSpeed.115200.upload.speed=115200
pico32.menu.UploadSpeed.256000.windows=256000
pico32.menu.UploadSpeed.256000.upload.speed=256000
pico32.menu.UploadSpeed.230400.windows.upload.speed=256000
pico32.menu.UploadSpeed.230400=230400
pico32.menu.UploadSpeed.230400.upload.speed=230400
pico32.menu.UploadSpeed.460800.linux=460800
pico32.menu.UploadSpeed.460800.macosx=460800
pico32.menu.UploadSpeed.460800.upload.speed=460800
pico32.menu.UploadSpeed.512000.windows=512000
pico32.menu.UploadSpeed.512000.upload.speed=512000
pico32.menu.DebugLevel.none=None
pico32.menu.DebugLevel.none.build.code_debug=0
pico32.menu.DebugLevel.error=Error
pico32.menu.DebugLevel.error.build.code_debug=1
pico32.menu.DebugLevel.warn=Warn
pico32.menu.DebugLevel.warn.build.code_debug=2
pico32.menu.DebugLevel.info=Info
pico32.menu.DebugLevel.info.build.code_debug=3
pico32.menu.DebugLevel.debug=Debug
pico32.menu.DebugLevel.debug.build.code_debug=4
pico32.menu.DebugLevel.verbose=Verbose
pico32.menu.DebugLevel.verbose.build.code_debug=5
You could delete them bit I just moved my boards nearer to the top
The situation is easier with IDE 2.0 because board selection works differently
The menu really blew up since they added support for the ESP32-C3, ESP32-S2, and ESP32-S3. There was some discussion about making it easier to navigate:
Unfortunately I haven't noticed any progress on the subject in the ESP32 platform repository since then.
Yesterday I made a simple editor to clone an ESP to have 2 identical ESPs with 2 different settings (so you can connect 2 devices and select a predefined configuration).
Maybe this can help you to reduce the quantity of ESP in this list (or I can update the script to remove just what you don't want).
It is a pure javascript page (you can download and edit it if you want):
Board editor
Hi @ptillisch You can see the reason in my reply here: Tools > Board > ESP32 > new submenu - #11 by ficeto
Does anybody know why there are two Arduino\hardware folder on the system drive?
I just noticed when looking for esp32 folder. I have installed 1.8.19 and 2.1.0 IDE also, but they are supposed to use common package in the Users folder, aren't they?
IDE 2.x only uses the latter.
For the older IDEs, the directory in program files only contains the initial (AVR) board package; upgrades of it or additional board packages will be installed in the AppData directory.
Okay, got it.
Thanks for the quick reply. ![]()
In order to allow new users to get started working with Arduino with the minimum amount of setup, the Arduino IDE 1.x installation includes a bundled copy of the "Arduino AVR Boards" platform for the popular boards like Uno, Mega, Nano, Leonardo. That bundled "Arduino AVR Boards" platform is stored in c:\Program Files (x86)\Arduino\hardware\. Any other platforms you install or update via the Arduino IDE Boards Manager will be installed under c:\Users\i5-10th\AppData\Local\Arduino15\packages
The approach of bundling the platform with the Arduino IDE installation is limiting because that bundled platform will be whichever version of "Arduino AVR Boards" was newest at the time of the Arduino IDE release, meaning that if a new release of "Arduino AVR Boards" was made after the time of the Arduino IDE, then Arduino is distributing an outdated version of the platform which might be missing important enhancements or fixes. For this reason, a different approach was taken when the IDE was completely rewritten for the 2.x series: Arduino IDE 2.x uses the Boards Manager infrastructure to automatically install the latest version of "Arduino AVR Boards" on the first run after a new release if the user doesn't already have a global installation of that platform. This means there is no equivalent of c:\Program Files (x86)\Arduino\hardware\ in the Arduino IDE 2.x installation folder.
Yes, this was my real concern actually, beacuse I compared them with WinMerge and they weren't the same. ![]()
So with the 1.x IDE if an Arduino AVR Boards install was made after the IDE installation, the AVR boards package under Program Files was never used later on?
And if I uninstall the 1.x IDE, the c:\Program Files (x86)\Arduino\hardware\ folder will be removed?
By the way, thanks for the clear explanation.
That is correct.
Correct.
You're welcome. I'm glad if I can be of assistance.
