Hi, i have an Arduino Opta that I'm using to develop teaching materials for a University course in Advanced Manufacturing, and I need to connect it to the Arduino Cloud. Direct deployment of a sketch from the cloud doesn't allow all the PLC aspects of the board, and so not useful. What I'm trying to do is build the sketch within the Arduino PLC IDE as if the board was a manually configured device. This requires:
However there doesn't seem to be any options within the IDE to install new libraries or point to existing ones. The Arduino_ConnectionHandler is there, but throws errors when it tries to use one of it's dependencies (Arduino_DebugUtils.h), and the ArduinoIoTCloud isn't there at all. Just looking for any guidance on how to include extra libraries and dependencies in the PLC IDE, thanks.
I found this post while looking for answers to use an Opta with the Arduino PLC IDE myself, so I thought I would share what I found. It seems you cannot manually install new libraries, but the IDE will allow you to point to existing public libraries. That includes only those libraries found at https://www.arduinolibraries.info/. The method to include public libraries can be found in the programming introduction for the PLC IDE, at https://docs.arduino.cc/software/plc-ide/tutorials/plc-programming-introduction/#library-management.
I am not sure how to get dependencies to work - in my case I was trying to use some features from mbed_mktime.h which are included in a sample sketch, but the PLC IDE apparently will not allow use of it.
Hi bwool, yes i managed to find the solution i was looking for. Noted it here also - Sketch libraries for Opta - #10 by dwholmesphd. The most useful part is the list of available libraries found in the C:\Users\[user]\AppData\Local\T\A folder. It's important to get the version right, and that file has all available versions for your PLC IDE install. Also, you can also use custom libraries if you put the library zip in the C:\Users\[user]\AppData\Local\T\D\libraries folder, but it won't manage dependencies automatically, so you might find yourself going down a rabbit hole of copy library, find dependency, copy new library, repeat.
Perfect, thank you for that additional information! I hadn't found that list or the process to use custom libraries yet, but they sound very helpful for my project.
To connect to the Arduino Cloud, the libraries listed below are required. Please make sure to add them, along with their latest version available on GitHub:
Thanks for bringing this to our attention. I have submitted a report on your behalf to the team at Arduino responsible for this documentation.
arduinolibraries.info is a 3rd party website created independently by a community member. Unfortunately, as is often the case with hobby projects, the website is not actively maintained. Fortunately Arduino has created our own official equivalent of the website:
This is only needed under one of the following specific conditions:
the library has not been registered with the Arduino Library Manager system
the library is in Library Manager, but you want to use an unstable development version of the library that is not available for installation from Library Manager
The "Arduino_Opta_Blueprint" library is in Library Manager, and you have not expressed the need to use a development version (the latest 0.2.8 release is state of the art anyway). So I don't think you have any need to install the library from GitHub. If you find you truly do have such a need, then you can let us know and the forum helpers will advise you on doing that.
Have you also included the dependencies for Arduino_Opta_Blueprint (i.e. Arduino_SerialUpdater and Arduino_DebugUtils). The entry that you find in the library_index.json that is in the AppData folder (see my post above regarding finding this) gives you all available versions and the resulting dependencies. In an Arduino IDE project, it’ll download those automatically, but in the PLC IDE you have to go down the rabbit hole manually (i.e. add those libraries and then check for their dependencies). On my install, Arduino_SerialUpdater there is only version 0.0.1 and it has no additional dependencies.
You might also try some earlier versions of the package you’re trying to use, as I’ve found that to work sometimes as well.
