So we have this project on our avionics class and after searching I found this guide to be effective for marker beacons:
and I have questions for it to fully function as a marker beacon which is like this:
My question is how can I make the LEDs blink and make the piezo buzzer beep.
This is the code that I used from the guide:
#define trigPin 7
#define echoPin 6
#define led 13
#define led2 12
#define led3 11
#define led4 10
#define led5 9
#define led6 8
#define buzzer 3
int sound = 250;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(buzzer, OUTPUT);
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance <= 30) {
digitalWrite(led, HIGH);
sound = 250;
else {
digitalWrite(led,LOW);
if (distance < 25) {
digitalWrite(led2, HIGH);
sound = 260;
else {
digitalWrite(led2, LOW);
if (distance < 20) {
digitalWrite(led3, HIGH);
sound = 270;
else {
digitalWrite(led3, LOW);
if (distance < 15) {
digitalWrite(led4, HIGH);
sound = 280;
else {
digitalWrite(led4,LOW);
if (distance < 10) {
digitalWrite(led5, HIGH);
sound = 290;
else {
digitalWrite(led5,LOW);
if (distance < 5) {
digitalWrite(led6, HIGH);
sound = 300;
else {
digitalWrite(led6,LOW);
if (distance > 30 || distance <= 0){
Serial.println("Out of range");
noTone(buzzer);
else {
Serial.print(distance);
Serial.println(" cm");
tone(buzzer, sound);
I tried adding this codes in the part where an LED turns on.
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
but the lights get delayed so much especially when changing distance at fast pace.
