Hi Everybody,
I am new in this forum. I am a french agronomist working on monitoring of physical parameters in agrosystems. I am developping a station based on the envirodiy SDI-12 library with Teros sensors from Decagon.
I am using the schema given in the Envirodiy documentation :
I read in the SDI-12 Documentation (page 4) and in the Teros 11/12 datasheet (page 3) that a minimal impedance was required when the transmiter is on or when the low power mode is activated.
When an SDI-12 device has its transmitter on, its direct current (DC) source resistance
must be greater than 1000 ohms and less than 2000 ohms
When any SDI-12
device’s transmitter is off, including during a low-power standby mode, the DC resistance to
ground must be within 160K to 360K ohms.
And especially (I am using a 3V alimentation and a 5V booster to supply sensors) :
If an SDI-12 sensor does not use the 12-volt line for
power, its data line resistance to ground while powered down must be within 160K to 360K ohms
My questions is :
– Are the components required in the circuit of the SDI-12 documentation/Teros data sheet (capacitors, resistance, …) already present in the sensor or is it compulsory and must be added to the circuit to supply and make the sensors working well?
For the moment, I have only one sensor using the envirodiy schema (it’s working well) and that’s why I want to know if the second schema from envirodiy is sufficient to use properly multiple sensors or if SDI-12 documentation modified circuit (resistance, capacitor, inductor) is needed to use them?
Thank you in advance for your advices.
