I'm doing an interesting experiment. But it is not working as I expected.
I have Arduino Due and Uno.
Here is my test.
- Flipped up UART TX/RX pins of each core chips.
- Connect USB to DUE board and connect wire as below
1)DUE0 pin to UNO board core RXD pin
2)DUE1 pin to UNO board core TXD pin
I've connected correctly.
As I guess, below is the procedure of the board.
- USB connected to DUE board.
- USB data converted to serial data by ATMEGA16U2 in DUE.
- Serial TX/RX signals go out through the wire which are connected on TX0, RX0 pin.
- wires connected to UNO chip serial pins.
- It acts like a single UNO board.
I tested IDE setting both Arduino UNO and DUE.
But it's not working and the message is as below. it's "not in sync".
To check the connection, I've tried the same thing in one board by wire.
It's working when I do it in one board.
What did I miss?
Arduino: 1.6.9 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 1,204 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 11 bytes (0%) of dynamic memory, leaving 2,037 bytes for local variables. Maximum is 2,048 bytes.
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd6
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
