Hello Friends,
First, I'm a newbie to arduino so any help is highly appreciated ! ![]()
My project is a simple voltage / current monitor device with ACS 758 sensor . Basically the sensed voltage / current is to be shown in a 16x2 LCD . Also making a data log into a SD card is essential .
I tested the circuit with ONLY with the SD CARD MODULE and another time ONLY with the LCD MODULE . BOTH WORKED . But i haven't tried connecting both at same time as I have a problem .
So I have the LCD and SD CARD MODULE ; but my problem is both modules use the same pins ( pin 11, pin 12, pin 4 ) ?
Please help me to proceed .
Many Thanks,
Dileesha.
According to arduino site, the pin configuration for LCD is as below ,
- LCD RS pin to digital pin 12
- LCD Enable pin to digital pin 11
- LCD D4 pin to digital pin 5
- LCD D5 pin to digital pin 4
- LCD D6 pin to digital pin 3
- LCD D7 pin to digital pin 2
- LCD R/W pin to ground
- 10K resistor:
- ends to +5V and ground
- wiper to LCD VO pin (pin 3)
LINK : http://arduino.cc/en/Tutorial/LiquidCrystal
According to SD CARD MODULE site, the pin configuration for SDCARD MODULE is as below ,
MODULE PINOUT:
PIN 1: GND ---> Arduino GND
PIN 2: +3.3V ---> Arduino 3V
PIN 3: +5V ---> Arduino 5V
PIN 4: CS ---> Arduino DIO 4
PIN 5: MOSI ---> Arduino DIO 11
PIN 6: SCLK ---> Arduino DIO 13
PIN 7: MISO ---> Arduino DIO 12
PIN 8: GND ---> N/AYou may copy, alter and reuse this code in any way you like but please leave
reference to HobbyComponents.com in your comments if you redistribute this code. */
LINK : Official Hobby Components Online Store | Buy Electronic Kits, Components, Boards, Shields, Modules
