Interface midi-usb with separate IN and OUT teensy3.6
Hello,
I'm trying to build a small midi interface with a teensy 3.6 card, and the following electric druid circuit: https://electricdruid.net/wp-content/uploads/2016/04/MIDISchematic-3.jpg
I upload the example code teensy3x3, (my goal, in the long run, is to make an interface with at least 2 inputs and 2 outputs, but I'm already testing with 1 in 1 out).
Everything works, but I would like to have this operation: IN1 -> USB, USB -> OUT1 or for now, I have IN1 -> USB + IN1 -> OUT1, USB -> OUT1.
I tried to change the numbers of the virtual cables but it doesn't work...
Here is the code:
```cpp
/* Create a "class compliant " USB to 3 MIDI IN and 3 MIDI OUT interface.
   MIDI receive (6N138 optocoupler) input circuit and series resistor
   outputs need to be connected to Serial1, Serial2 and Serial3.
   You must select MIDIx4 from the "Tools > USB Type" menu
   This example code is in the public domain.
#include <MIDI.h>
// Create the Serial MIDI ports
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI1);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial2, MIDI2);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial3, MIDI3);
// A variable to know how long the LED has been turned on
elapsedMillis ledOnMillis;
  pinMode(13, OUTPUT); // LED pin
  digitalWrite(13, LOW);
  MIDI1.begin(MIDI_CHANNEL_OMNI);
  MIDI2.begin(MIDI_CHANNEL_OMNI);
  MIDI3.begin(MIDI_CHANNEL_OMNI);
  bool activity = false;
  if (MIDI1.read()) {
    // get a MIDI IN1 (Serial) message
    byte type = MIDI1.getType();
    byte channel = MIDI1.getChannel();
    byte data1 = MIDI1.getData1();
    byte data2 = MIDI1.getData2();
    // forward the message to USB MIDI virtual cable #0
    if (type != midi::SystemExclusive) {
      // Normal messages, simply give the data to the usbMIDI.send()
      usbMIDI.send(type, data1, data2, channel, 3);
      // SysEx messages are special.  The message length is given in data1 & data2
      unsigned int SysExLength = data1 + data2 * 256;
      usbMIDI.sendSysEx(SysExLength, MIDI1.getSysExArray(), true, 0);
    activity = true;
  if (MIDI2.read()) {
    // get a MIDI IN2 (Serial) message
    byte type = MIDI2.getType();
    byte channel = MIDI2.getChannel();
    byte data1 = MIDI2.getData1();
    byte data2 = MIDI2.getData2();
    // forward the message to USB MIDI virtual cable #1
      usbMIDI.send(type, data1, data2, channel, 4);
      usbMIDI.sendSysEx(SysExLength, MIDI1.getSysExArray(), true, 1);
    activity = true;
  if (MIDI3.read()) {
    byte type = MIDI3.getType();
    byte channel = MIDI3.getChannel();
    byte data1 = MIDI3.getData1();
    byte data2 = MIDI3.getData2();
      usbMIDI.send(type, data1, data2, channel, 5);
      usbMIDI.sendSysEx(SysExLength, MIDI1.getSysExArray(), true, 2);
    activity = true;
  if (usbMIDI.read()) {
    // get the USB MIDI message, defined by these 5 numbers (except SysEX)
    byte type = usbMIDI.getType();
    byte channel = usbMIDI.getChannel();
    byte data1 = usbMIDI.getData1();
    byte data2 = usbMIDI.getData2();
    byte cable = usbMIDI.getCable();
    // forward this message to 1 of the 3 Serial MIDI OUT ports
    if (type != usbMIDI.SystemExclusive) {
      // Normal messages, first we must convert usbMIDI's type (an ordinary
      // byte) to the MIDI library's special MidiType.
      midi::MidiType mtype = (midi::MidiType)type;
      // Then simply give the data to the MIDI library send()
      switch (cable) {
        case 0:
          MIDI1.send(mtype, data1, data2, channel);
        case 1:
          MIDI2.send(mtype, data1, data2, channel);
        case 2:
          MIDI3.send(mtype, data1, data2, channel);
        case 3:
        case 4:
        case 5:
      switch (cable) {
        case 0:
          MIDI1.sendSysEx(SysExLength, usbMIDI.getSysExArray(), true);
        case 1:
          MIDI2.sendSysEx(SysExLength, usbMIDI.getSysExArray(), true);
        case 2:
          MIDI3.sendSysEx(SysExLength, usbMIDI.getSysExArray(), true);
    activity = true;
  // blink the LED when any activity has happened
  if (activity) {
    digitalWriteFast(13, HIGH); // LED on
    ledOnMillis = 0;
  if (ledOnMillis > 15) {
    digitalWriteFast(13, LOW);  // LED off
It looks like you need to turn off the midi thru:-
  MIDIUART.begin(MIDI_CHANNEL_OMNI);
  MIDIUART.turnThruOff();
Thank you, I tried, but it sends me an error:
Compilation error: 'MIDIUART' was not declared in this scope
Thanks a lot
This code works :
MIDI1.turnThruOff();
