how can i do the above?
How can i create my own library?
Help would be appreciated.
Thank u
Thank u
For what sensor.
There are many tutorials on creating Arduino libraries that will show up with a Google search.
Your questions are so general that answers must be as well.
To learn how to interface with a sensor you would read the sensor's datasheet. Often they will describe how to connect the sensor to a microcomputer and how to send and receive data.
To write a library you would typically design a C++ object to represent the sensor, declare it in a .h file and define the functions in a .cpp file. Put them in a folder of the same name under 'libraries' in your sketch folder.
thank u .. i will look into it..
You do not normally need to create a library just to access a sensor. Whether or not to put the code in a library is a separate decision.
...R
