would it be possible to hook a arduino up to a usb keyboard and respond to keypresses. And no i don't want to hack the keyboard. the goal is to make a device that sits between keyboard and computer. so it should only listen to messages, but not send them.
is there a "sniffer" like library around to use a digital pin as a usb input?
Search the forums a bit (tip: use google by typing "site:arduino.cc keywords" in the google search box). There was a reasonably extensive discussion on this subject a while back.
Short answer: nope. AVR isn't fast enough to capture and process the data.
i've given up the idea. i was planning a device that produces typewriter sounds when pressing key's. but that is easier done in just software than hacking usb...
If you still want to do this project then an easy way to implement USB is by using the Create USB Interface www.create.ucsb.edu/%7Edano/CUI/
This allows easy access to the complex protocol as a HID (Human Interface Device) which is the class of device that includes keyboards.
