Interfacing a 24V linear actuator to Arduino Uno
Dear professionals,
I am currently working on a project which requires me to control the direction and length of the linear actuator's extension and I have basic knowledge on H-Bridge drivers like L298N and SN754410. Therefore i would like to stick to either of these chips. I'm currently testing out using the SN754410 chip to extend the actuator, however, its not working out. I have no idea how to feed a 24v supply to the actuator through the arduino as the maximum voltage recommended is 20V. Any suggestions of other alternatives are welcomed.
my current program is
const int switchPin = 2; // switch input
const int motor1Pin = 3; // H-bridge leg 1 (pin 2, 1A)
const int motor2Pin = 4; // H-bridge leg 2 (pin 7, 2A)
const int enablePin = 9; // H-bridge enable pin
// set the switch as an input:
pinMode(switchPin, INPUT);
// set all the other pins you're using as outputs:
pinMode(motor1Pin, OUTPUT);
pinMode(motor2Pin, OUTPUT);
pinMode(enablePin, OUTPUT);
// set enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
// if the switch is high, motor will turn on one direction:
if (digitalRead(switchPin) == HIGH) {
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor2Pin, HIGH); // set leg 2 of the H-bridge high
// if the switch is low, motor will turn in the other direction:
else {
digitalWrite(motor1Pin, HIGH); // set leg 1 of the H-bridge high
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge low
Some details of the materials i have:
1.Linear Actuator : Linak (LA-30) 24V
2.Arduino Uno
3.24V batteries
4.L298N
5.SN754410
If the L298N or SN754410 can't handle 24V (is that what you are saying?) then you have to find a chip that does.
The L293 can handle 36V.
Also if you are using batteries and they get charged at some point you are looking at having around 30V at times.
EDIT: Just checked, the L298 is good for 46V and the SN754410 36V. So what's the problem again?
The 24V doesn't go through the Arduino, in fact it doesn't go anywhere near it. I've not used these chips but here are some observations.
VCC2 (pin 8 ) should go to 24V.
VCC1 (pin 16) should go to Arduino's 5V.
GNDs go directly to the 24V battery GND but the battery GND and the Arduino GND must also be connected.
Rob
