Good morning
I have arduino, H bridge and Linear Actuator with feedback potentiometer
I want to make actuator move from position for example 18 mm to position 2 25 mm
What is the code for this control ?
int RPWM = 10;
int LPWM = 11;
int sensorPin = A0;
int sensorVal;
int Speed=255;
float strokeLength = 6.0; //customize to your specific stroke length
float extensionLength;
int maxAnalogReading;
int minAnalogReading;
pinMode(RPWM, OUTPUT);
pinMode(LPWM, OUTPUT);
pinMode(sensorPin, INPUT);
maxAnalogReading = moveToLimit(1);
minAnalogReading = moveToLimit(-1);
void loop(){
Serial.println("Extending...");
sensorVal = analogRead(sensorPin);
while(sensorVal < maxAnalogReading){
driveActuator(1, Speed);
displayOutput();
delay(20);
driveActuator(0, Speed);
Serial.println("Retracting...");
while(sensorVal > minAnalogReading){
driveActuator(-1, Speed);
displayOutput();
delay(20);
int moveToLimit(int Direction){
int prevReading=0;
int currReading=0;
do{
prevReading = currReading;
driveActuator(Direction, Speed);
timeElapsed = 0;
while(timeElapsed < 200){ delay(1);} //keep moving until analog reading remains the same for 200ms
currReading = analogRead(sensorPin);
}while(prevReading != currReading);
return currReading;
float mapfloat(float x, float inputMin, float inputMax, float outputMin, float outputMax){
return (x-inputMin)*(outputMax - outputMin)/(inputMax - inputMin)+outputMin;
void displayOutput(){
extensionLength = mapfloat(sensorVal, float(minAnalogReading), float(maxAnalogReading), 0.0, strokeLength);
Serial.print("Analog Reading: ");
Serial.print(sensorVal);
Serial.print("\tActuator extension length: ");
Serial.print(extensionLength);
Serial.println(" inches");
void driveActuator(int Direction, int Speed){
switch(Direction){
case 1: //extension
analogWrite(RPWM, Speed);
analogWrite(LPWM, 0);
case 0: //stopping
analogWrite(RPWM, 0);
case -1: //retraction
analogWrite(LPWM, Speed);
I found this code on internet but this one is for maximum and minimum values and as i mentioned in the question my actuator starts from 18 mm and i want to move it to 25 mm
