I'm creating an ultrasonic flow-meter using the TDC1000, TDC7200, and Arduino MKR1000. Since this is my first time working with SPI, I thought I'd start by just reading and writing to and from CONFIG_0 on the TDC1000.
The arduino only reads zeros.
I've tried all the arduino's different SPI modes (0-3).
After a couple weeks I can't figure out what I'm doing wrong. I would greatly appreciate help in troubleshooting the below code.
Thanks.
#include <SPI.h>
int selectTDC1000 = 5;
int selectTDC7200 = 0;
int enableTDC1000 = 7;
int enableTDC7200 = 1;
int dataReadyPin = 4;
int channelSelect = 3;
byte CONFIG1_address = 0x00;
byte CONFIG1_instruction = 0x00;
unsigned int whatWasRead = 0x00;
unsigned int readRegister(int device, byte address, int bytesToRead);
void writeRegister(int device, byte address, byte data);
SPI.beginTransaction(SPISettings(16000000, MSBFIRST, SPI_MODE0));
pinMode(selectTDC1000, OUTPUT);
pinMode(selectTDC7200, OUTPUT);
pinMode(enableTDC1000, OUTPUT);
pinMode(enableTDC7200, OUTPUT);
pinMode(dataReadyPin, INPUT);
pinMode(channelSelect, OUTPUT);
digitalWrite(selectTDC1000, HIGH);//active low
digitalWrite(selectTDC7200, HIGH);//active low
digitalWrite(enableTDC1000, LOW);
digitalWrite(enableTDC7200, LOW);
digitalWrite(enableTDC1000, HIGH);
delayMicroseconds(350);
//***Read and print register***********************************
whatWasRead = readRegister(1000, CONFIG1_address, 1);
Serial.print("Before write: ");
Serial.println(whatWasRead, BIN);
//***Write new byte to register, read byte from register*******
writeRegister(1000, CONFIG1_address, 0x02);
Serial.print("After write: ");
Serial.print("\n");
if(device == 1000)
digitalWrite(selectTDC1000, LOW);//low active
else if(device == 7200)
digitalWrite(selectTDC7200, LOW);//low active
address |= 1000000;
SPI.transfer(address);
SPI.transfer(data);
if(device == 1000)
digitalWrite(selectTDC1000, HIGH);//low active
digitalWrite(selectTDC7200, HIGH);//low active
/* device: 1000 or 7200.
* address: register address on specified device.
* how many bytes long is the data we're reading?
byte inByte = 0; // incoming byte from the SPI
unsigned int result = 0; // result to return
Serial.print("Address we're reading from: ");
Serial.print(address, BIN);
Serial.print("\n");
if(device == 1000)
byte readFromThisRegister = address;//read bit comes before address (MSBF) so 0b000000 = 0b0000000
SPI.transfer(readFromThisRegister);
result = SPI.transfer(0x00);
bytesToRead --;
while(bytesToRead > 0)
result = result << 8;
inByte = SPI.transfer(0x00);
result = result | inByte;
bytesToRead --;
if(device == 1000)
return result;
