Communicating SPI with AD5293
Hi thanks to let me participate in this forum.
I have been trying to establish SPI communication with Arduino UNO and MKR100 wifi, using all the trick on the many article I read. At this point I have no a clue in how to make it happen.
I used a logical analyzer, the commands I send look right but the chip doesn't respond.
Please, let me know what information you need from me.
I hope someone can enlighten me and get it work.
Thanks
Aldo Grossi
Please, post your codes that you have tried with Arduino UNO.
Post a wiring diagram. The MKR1010 is a 3.3V device but the UNO is a 5V device. You must not connect them directly, you have to use level converters.
Thanks, for helping me.
I am attaching the Arduino code and the schematic.
Thanks
Aldo Grossi
MKR1000WiFi_SPI.pdf (168 KB)
AD5293_SPI.ino (1.32 KB)
Sorry Wrong Sketch file
  SPI.setClockDivider(128);// Set Clock Rate
Set the clock divider to 4 or 8. The chip is more than fast enough to read the signal.
How do you know? You don't check the RDY signal.
