Im trying to display characters on LED display of TM1638,my controller is dspic30f5011.
i have done my code based on datasheet(TM1638),but i'm unable to get data on display.
can some one help me please.
Regards,
khaleel
Regards,
khaleel
can you give the sketch here???
khaleelarya:
Hi,Im trying to display characters on LED display of TM1638,my controller is dspic30f5011.
Regards,
khaleel
gonnie08:
In addition to what gonnie said, also post a drawing of how you connected it to the Arduino, Which Arduino are you usings?
Chuck.
I'm not using Arduino,my controller is dspic30f5011.
connections as below
controller TM1638
SCKL -------------->CLK
CS -------------->STB
DOUT-------------->DIO
DIN -------------->open(I'm not reading any data fromTM1638)
writing sequence
CS = 0; // enabling the communication
DelayTcy(2);
WriteSPI2(0x44); // Data Command Set with Write data Mode and fixed Address
DelayTcy(10); // Delay of 1us
CS = 1; // disabling communication
DelayTcy(10);
CS = 0;
WriteSPI2(0xC0); // Set the Display Adress initial 0x00
DelayTcy(10);
WriteSPI2(0x40); // Transmission of Data 0
DelayTcy(10);
CS = 1;
DelayTcy(10);
CS = 0;
WriteSPI2(0x8F); // Brightness Control and switch On display
DelayTcy(10);
CS = 1;
and here is my writeSPI function
void WriteSPI2(unsigned int data_out)
if (SPI2CONbits.MODE16) // word write
SPI2BUF = data_out;
SPI2BUF = data_out & 0xFF; // byte write
khaleelarya:
I'll be of no help, I do not have any knowledge of dspic30f5011.
Sorry.
chuck.
