tldr; How do I interface this joystick's buttons with my Arduino - without using the USB interface?
Skip to "---the project---" below if you don't want to get bored reading.
Morning all,
-----my arduino experiene ------
My experience is quite low level use of arduino to hack various existing things. For example:
- Automating a manual roller blind sign originally from the front of a bus; and
- using an xbox controller as a PWM slot car controller at my local track.
I'm moving more into robotics, and getting familiar with the ubuquitous IR and ultrasonic sensors etc.
I have a variely of servo controlled projects at the moment, including a 3d printed robot arm. I'd like to be bable to control them with a joystick.
------ the project ------------
I'm using a Logitech Extreme Pro 3D i got from freecycle. it has 4 pots and about a million buttons (4 of which create a mini-joystick on top)
I am tapping into the analog side of the circuitry, so am not using the USB interface except to provide power.
So far I've completed the following steps:
- Attach arduino 5v rail and GND to internal 5v/GRND internally to get power running to the pots.
- Tap each pot wiper for connection to an analog pin.
I'm a bit confused about the buttons. They are the familiar push-to-make momentary switches, but I cannot work out if they pull-up / down etc.
The buttons themselves are mounted on 2 PCBs, which plug in to the main PCB with connectors.
- Up top there are 10 switches (including 4 for mini joystick) - 7 wires come from this PCB.
- On the side of the joystick there are six buttons a few diodes on a PCB - 6 wires come from this PCB.
I can attach photos of the PCBs if that helps?
Anyone have any idea how I should be approaching hooking up these buttons. Presumably I can add each to a digital input to pull it high/low?
I only have a DMM at my disposal for testing - no scope.
