Interfacing the ESP32 to read data using two SPI lines
Hello everyone,
I am working on a project and I have recently switched from the Arduino nano to an ESP32. I have the VSPI line working reading data from the accelerometer. I would like to use VSPI for the accelerometer as I plan to use HSPI for an SD card module. How do I change the SPI settings to use the HSPI as well?
//Testing the LIS3DH on the esp32
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
//ACCELEROMETER SPI SETUP
// Used for hardware & software SPI
#define LIS3DH_CS 5
// hardware SPI
Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
//ACCELEROMETER DATA COLLECTION SETUP
#define SIZE 2000 //size of array 400 gets 2000 samples/sec ... sadly not anymore
float samples[SIZE][4]; //declare variable for sample storage
//Retrieve the data from the sensor
void getData() {
  //Collect data from the sensor
  for(int i=0; i<SIZE; i++){
  lis.read();      // get X Y and Z data at once
  // Then print out the raw data
  /*Serial.print("X:  "); Serial.print(lis.x);
  Serial.print("  \tY:  "); Serial.print(lis.y);
  Serial.print("  \tZ:  "); Serial.print(lis.z);
  /* Or....get a new sensor event, normalized */
  sensors_event_t event;
  lis.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  /*Serial.print("\t\tX: "); Serial.print(event.acceleration.x);
  Serial.print(" \tY: "); Serial.print(event.acceleration.y);
  Serial.print(" \tZ: "); Serial.print(event.acceleration.z);
  Serial.println(" m/s^2 ");
  //collect the data in blocks
      samples[i][0] = micros();
      samples[i][1] = event.acceleration.x;
      samples[i][2] = event.acceleration.y;
      samples[i][3] = event.acceleration.z;
//Write the data to serial
void writeData() {
    for(int i=0; i<SIZE; i++) {
      Serial.print(samples[i][0]);
      Serial.print(",");
      Serial.print(samples[i][1]);
      Serial.print(",");
      Serial.print(samples[i][2]);
      Serial.print(",");
      Serial.print(samples[i][3]);
      Serial.print("\n");
  pinMode(LIS3DH_CS, OUTPUT);
  delay(4000);
  SPI.begin();
//setup the sensor
  Serial.println("LIS3DH test!");
  if (! lis.begin(0x18)) {   // change this to 0x19 for alternative i2c address
    Serial.println("Couldnt start");
    while (1) yield();
  Serial.println("LIS3DH found!");
  // lis.setRange(LIS3DH_RANGE_4_G);   // 2, 4, 8 or 16 G!
  Serial.print("Range = "); Serial.print(2 << lis.getRange());
  Serial.println("G");
  lis.setDataRate(LIS3DH_DATARATE_LOWPOWER_5KHZ);
  Serial.print("Data rate set to: ");
  switch (lis.getDataRate()) {
    case LIS3DH_DATARATE_1_HZ: Serial.println("1 Hz"); break;
    case LIS3DH_DATARATE_10_HZ: Serial.println("10 Hz"); break;
    case LIS3DH_DATARATE_25_HZ: Serial.println("25 Hz"); break;
    case LIS3DH_DATARATE_50_HZ: Serial.println("50 Hz"); break;
    case LIS3DH_DATARATE_100_HZ: Serial.println("100 Hz"); break;
    case LIS3DH_DATARATE_200_HZ: Serial.println("200 Hz"); break;
    case LIS3DH_DATARATE_400_HZ: Serial.println("400 Hz"); break;
    case LIS3DH_DATARATE_POWERDOWN: Serial.println("Powered Down"); break;
    case LIS3DH_DATARATE_LOWPOWER_5KHZ: Serial.println("5 Khz Low Power"); break;
    case LIS3DH_DATARATE_LOWPOWER_1K6HZ: Serial.println("16 Khz Low Power"); break;
  Serial.print("Test");
  Serial.println("Test ln");
  //getData();
  //writeData();
Thank you in advance
Why would you need two separate instances of SPI?
SPI is intended for connection to multiple devices. The MOSI, MISO and SCLK lines are shared by all devices and then each device has its own CS connection.
...R
The ESP32 has two separate SPI busses, VSPI and HSPI with their own MISO and MOSI pins. I want to use them both so I can have one core on the ESP writing to an SD card while another one is reading from the accelerometer (since I need 2000 samples per second). I am just not sure how to initiate the HSPI since it is not the default when you call SPI.begin.
