Hi all...
I'm hooking an ethernet shield equipped Arduino up to a little thermal printer so it can automatically print out twitter messages. Since I wanted to make use of DHCP and DNS lookups I've been doing the Arduino coding with Arduino 1.0 Beta. The idea is that the sketch will periodically hit a web service that will return the latest tweet, and then I'll be able to send the message to the printer.
All of the printer stuff is working fine, but the web client part of things seems completely hit and miss. Some times it connects and receives content from the web service, other times it just hangs. For the life of me, I can't see what's wrong. Does anyone have any suggestions? Here's the code...
#include <SPI.h>
#include <Ethernet.h>
#include <icrmacros.h>
#include <SoftwareSerial.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
0x90, 0xA2, 0xDA, 0x00, 0x3A, 0x17 };
int checkDelay = 10000;
String twitterSearch = "%40chrisspurgeon";
String numberOfTweets = "1";
String twitterID = "0";
SoftwareSerial Thermal(2, 3); //Soft RX from printer on D2, soft TX out to printer on D3
// Printer inits
#define FALSE 0
#define TRUE 1
int printOnBlack = FALSE;
int printUpSideDown = FALSE;
int ledPin = 13;
int heatTime = 255; //80 is default from page 23 of datasheet. Controls speed of printing and darkness
int heatInterval = 255; //2 is default from page 23 of datasheet. Controls speed of printing and darkness
char printDensity = 15; //Not sure what the defaut is. Testing shows the max helps darken text. From page 23.
char printBreakTime = 15; //Not sure what the defaut is. Testing shows the max helps darken text. From page 23.
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
Client client;
Serial.begin(38400); //Use hardware serial for debugging
Thermal.begin(19200); //Setup soft serial for ThermalPrinter control
//Modify the print speed and heat
Thermal.write(27);
Thermal.write(55);
Thermal.write(7); //Default 64 dots = 8*('7'+1)
Thermal.write(heatTime); //Default 80 or 800us
Thermal.write(heatInterval); //Default 2 or 20us
//Modify the print density and timeout
Thermal.write(18);
Thermal.write(35);
int printSetting = (printDensity<<4) | printBreakTime;
Thermal.write(printSetting); //Combination of printDensity and printBreakTime
Serial.println("Printer parameters set");
Serial.println("Attempting to get an IP address...");
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// print your local IP address:
Serial.print("My IP address: ");
Thermal.print("My IP address is: ");
for (byte thisByte = 0; thisByte < 4; thisByte++) {
// print the value of each byte of the IP address:
Serial.print(Ethernet.localIP()[thisByte], DEC);
Serial.print(".");
Thermal.print(Ethernet.localIP()[thisByte], DEC);
Thermal.print(".");
for (int i = 0; i < 3; i++) {
// Thermal.println();
Thermal.write(10);
delay(5000);
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
Thermal.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Thermal.println();
Serial.println("disconnecting.");
client.stop();
client.flush();
delay(checkDelay);
Serial.println("Trying to connect again...");
if (client.connect("216.119.67.135",80)) {
Serial.println("connected");
client.println("GET /twitterfeed/tweets.php?rpp=" + numberOfTweets + "&q=" + twitterSearch + "&since_id=" + twitterID + " HTTP/1.0");
// Attempting to hit this URL...
// http://216.119.67.135/twitterfeed/tweets.php?rpp=1&q=%40chrisspurgeon&since_id=0
client.println();
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
Thanks in advance for any help!
