internal pull-up with optocoupler problem
Hello.
I need to connected 24V laser proximity sensor to arduino. To keep power lines separately I used optocoupler(4N32). For the schematic, see the attached pic. I want to use only internal pull-up. But a problem came up.
I wrote this simple test code:
  int S1= 2;
// the setup routine runs once when you press reset:
  Serial.print("started");
  pinMode(S1,INPUT_PULLUP);
// the loop routine runs over and over again forever:
   if(digitalRead(S1) == LOW){
     Serial.println(millis());
     Serial.println("pin LOW");
And as a result it allways prints to me "pin LOW". Voltage on that pin is 4,2V. Which should be "high". Why doesnt it work? Why it has a voltage drop, eventhough sensor output is 0V?
Hi, you are only testing and sending the LOW state, you will have to test for HIGH and send high .
Tom..... :slight_smile:
TomGeorge:
But how can it execute "Serial.println("pin LOW") command, when the IF sentence condition is not true?
I tried testing high state also. It works most of the time, but still sometimes it says "pin low" when the sensor is not activated. (see the pic).
I would suspect that it is not wired up like you think.
How about a photo correctly sized?
Grumpy_Mike:
You mean that i wired it up wrongly? I dont think so. If i add external pull-up it works perfectly. Just cant figure out, why not with the internal pull-up.
What is the max pohoto size? :* I just used win snipping tool...sorry
If you withhold vital information you can not expect to have a correct reply. So what value of external pull up did you use? It is important.
Don't post anything greater than 1000 pixels wide.
There is a "How to use this forum" sticky post please read it.
Hi, please look at.
http://forum.arduino.cc/index.php/topic,148850.0.html
Gives you ll the hints on our to get the most out of your post.
Tom... :slight_smile:
I suppose it's possible that the internal pullup is stuffed; have you tried a different pin?
JimboZA:
It is indeed, that was going to be my next point. 8)
Grumpy_Mike:
JimboZA:
Or as The IT Crowd fans would know... have you tried turning it off and on again mate?
Sorry for delayed answer. The problem was due to using breadboard. After I made soldered connection everything worked ok. :roll_eyes:
