EDITED in response to first reply to clear up confusion.
So I am currently trying to code a simple setup for my Arduino Pro Mini (temporarily); there is a voltage input from a circuit board into Pin 3, which is one of 2 values: 1.3V or 4.2V.
However, the interrupts don't seem to trigger even when I use a raising edge when the voltage shifts from 1.3V to 4.2V. The last time I checked, If the voltage was below 1.7V it would be a LOW signal and I thought 4.2V would definitely be identified as a HIGH voltage... although I may be wrong.
Stuff I have done:
Replaced the interrupt with a digitalRead(3) --digitalRead seems to work, but interrupt doesn't
Probed the voltages on an oscilloscope AND Voltmeter to make sure the voltages are changing as intended
Currently I have an LED light attached to Pin 6 as a visual indicator that the trigger is working... it isn't.
I have commented out the digitalRead code for now, but I attached it as part of a comment for transparency. When I comment out the interrupt and uncomment the digitalRead, this setup works as intended. The code doesn't error... It just doesn't turn on the LED light ever, even when the voltage going into the interrupt changes
int circuit_power = 4;
int reading_input = 3;
int circuit_ground = 5;
volatile byte state = LOW;
pinMode(circuit_power, OUTPUT);
pinMode(reading_input, INPUT);
pinMode(circuit_ground, OUTPUT);
pinMode(6, OUTPUT);
attachInterrupt(digitalPinToInterrupt(reading_input), pressure_alert,RISING);
attachInterrupt(digitalPinToInterrupt(reading_input), testing, FALLING);
digitalWrite(circuit_power, HIGH);
digitalWrite(circuit_ground, LOW);
if (digitalRead(reading_input) == LOW){
state = LOW;
else{
state = HIGH;
digitalWrite(6, state);
void pressure_alert(){
state = HIGH;
void testing(){
state = HIGH;
