Hi all,
First time poster with a question. I have written a program and it's failing to execute how I had hoped. It only executes either openDoor() or ISR(ANALOG_COMP_vect) once and then requires a reset to run again or run the other routine. I must be missing something somewhere in my code... any suggestions?
//PIN DECLARATIONS
// this constant won't change:
const int relayPinClose = 14; // the pin that the close relay is attached to
const int relayPinOpen = 15; //the pin that the open relay is attached to
//VARIABLES
volatile long delta_t; //used for determining if rotor is rotating
//PROTOTYPES
void doorOpen(void);
int getrpm(void);
//pins to control door latch motor
pinMode(relayPinOpen, OUTPUT);
pinMode(relayPinClose, OUTPUT);
//make sure we're not opening/closing the latch
digitalWrite(relayPinOpen,0);
digitalWrite(relayPinClose,0);
//setup external interrupts
//attachInterrupt(0,doorLockDisable,HIGH); //used later on - but it is being used -DON'T FORGET
attachInterrupt(1,openDoor, FALLING);
//setup Analog comparator
ACSR =
(0<<ACD) | //analog comparator: enabled
(0<<ACBG) | //analog comp bandgap select: AIN0 is positive input
(1<<ACIE) | //analog comp interrupt: enabled
(0<<ACIC) | //analog comp input capture: disabled
(1<<ACIS1) | (0<<ACIS0); //analog comp interrupt mode: rising
DIDR1 = (1<<AIN1D) | (1<<AIN0D); //disable digital input buffer (saves power)
//setup interrupt for PCINT1
PCICR = (0<<PCIE2) | (1<<PCIE1) | (0<<PCIE0); //enable pins PCINT14..8 for pin change interrupt
PCMSK1 =
(0<<PCINT14) |
(0<<PCINT13) |
(0<<PCINT12) |
(0<<PCINT11) |
(1<<PCINT10) | //enables PCINT10 (ADC2 pin 25) as external interrupt
(0<<PCINT9) |
(0<<PCINT8);
//when the open button is pressed the door will open if the system says it's safe
void openDoor()
static unsigned long last_interrupt_time=0;
unsigned long interrupt_time = millis();
//if interrupts come faster than 200ms, assume it's a bounce and ignore
if (interrupt_time - last_interrupt_time > 200)
//if time between rotor pulses is less than 1000ms - door safe to open
//if(delta_t > 1000)
digitalWrite(relayPinClose,0); //make sure we don't short the motor
digitalWrite(relayPinOpen, 1);
delay(200);
attachInterrupt(0,doorLockDisable, HIGH);
last_interrupt_time = interrupt_time;
//when the door is closed turn the motor on to lock it closed
static unsigned long last_interrupt_time = 0;
digitalWrite(relayPinOpen,0); //make sure we don't short motor
digitalWrite(relayPinClose, 1); //writes the output of the analog comp
delay(200); //wait for lock switch to close (dual purpose switch)
attachInterrupt(0,doorLockDisable, HIGH); //enable the doorLocked interrupt
//when the door is fully locked/unlocked (as indicated by the switch) disable
//the motor
void doorLockDisable()
digitalWrite(relayPinClose, 0);
detachInterrupt(0);
ISR(PCINT1_vect)
//determine time between pulses
static long last_time;
long this_time;
//get the current micros count
this_time = millis();
//time between pulses
delta_t = this_time - last_time;
//set last time
last_time = this_time;
