I'm working on code to sync linear actuators with Hall sensors, and moving to the Giga R1 from my test Uno R4, the board is locking up with this code(4 slow red, 4 fast), that runs correctly on the Uno.
Wondering if I need to define or attach the interrupts differently?
Or maybe I'm missing something else entirely that differs in functionality.
This is a calibration program by Firgelli automations:
/* Modified by RacingToGreen from Firgelli Automations Code
#include <elapsedMillis.h>
elapsedMillis timeElapsed;
#define numberOfActuators 2
int RPWM[numberOfActuators]={22,23}; //PWM signal right side
int LPWM[numberOfActuators]={24,25};
int opticalPins[numberOfActuators]={51,52}; //connect optical pins to interrupt pins on Arduino. More information: https://www.arduino.cc/reference/en/language/functions/external-interrupts/attachinterrupt/
volatile long lastDebounceTime_0=0; //timer for when interrupt was triggered
volatile long lastDebounceTime_1=0;
int Speed = 100; //choose any speed in the range [0, 255]
#define falsepulseDelay 5 //noise pulse time, if too high, ISR will miss pulses.
volatile int counter[numberOfActuators]={};
volatile int prevCounter[numberOfActuators]={};
int Direction; //-1 = retracting
// 0 = stopped
// 1 = extending
int extensionCount[numberOfActuators] = {};
int retractionCount[numberOfActuators] = {};
int pulseTotal[numberOfActuators]={}; //stores number of pulses in one full extension/actuation
void setup(){
for(int i=0; i<numberOfActuators; i++){
pinMode(RPWM[i],OUTPUT);
pinMode(LPWM[i], OUTPUT);
pinMode(opticalPins[i], INPUT_PULLUP);
counter[i]=0; //initialize variables as array of zeros
prevCounter[i]=0;
extensionCount[i] = 0;
retractionCount[i] = 0;
pulseTotal[i] = 0;
attachInterrupt(digitalPinToInterrupt(opticalPins[0]), count_0, RISING);
attachInterrupt(digitalPinToInterrupt(opticalPins[1]), count_1, RISING);
Serial.println("Initializing calibration");
Serial.println("Actuator retracting...");
Direction = -1;
moveTillLimit(Direction, 255);
Serial.println("Actuator fully retracted");
Serial.print("\t\t\t\tActuator ");
Serial.print(i);
Direction = 1;
moveTillLimit(Direction, 255); //extend fully and count pulses
Serial.print("\nExtension Count:");
extensionCount[i]=counter[i];
Serial.print("\t\t");
Serial.print(extensionCount[i]);
Serial.print("\t\t\t");
Direction = -1;
moveTillLimit(Direction, 255); //retract fully and count pulses
Serial.print("\nRetraction Count:");
retractionCount[i]=counter[i];
Serial.print(abs(retractionCount[i]));
Serial.print("\n");
Serial.print("\nActuator ");
Serial.print(i);
Serial.print(" average pulses: ");
pulseTotal[i]=(extensionCount[i]+abs(retractionCount[i]))/2; //takes the average of measurements
Serial.print(pulseTotal[i]);
Serial.println("\n\nEnter these values in the synchronous control progam.");
void moveTillLimit(int Direction, int Speed){
//this function moves the actuator to one of its limits
for(int i = 0; i < numberOfActuators; i++){
counter[i] = 0; //reset counter variables
prevCounter[i] = 0;
do {
for(int i = 0; i < numberOfActuators; i++) {
prevCounter[i] = counter[i];
timeElapsed = 0;
while(timeElapsed < 200){ //keep moving until counter remains the same for a short duration of time
driveActuator(i, Direction, Speed);
} while(compareCounter(prevCounter, counter)); //loop until all counts remain the same
bool compareCounter(volatile int prevCounter[], volatile int counter[]){
//compares two arrays and returns false when every element of one array is the same as its corresponding indexed element in the other array
bool areUnequal = true;
if(prevCounter[i] == counter[i]){
areUnequal = false;
else{ //if even one pair of elements are unequal the entire function returns true
areUnequal = true;
return areUnequal;
void driveActuator(int Actuator, int Direction, int Speed){
int rightPWM=RPWM[Actuator];
int leftPWM=LPWM[Actuator];
switch(Direction){
case 1: //extension
analogWrite(rightPWM, Speed);
analogWrite(leftPWM, 0);
case 0: //stopping
analogWrite(rightPWM, 0);
case -1: //retraction
analogWrite(leftPWM, Speed);
void count_0(){
//This interrupt function increments a counter corresponding to changes in the optical pin status
if ((millis() - lastDebounceTime_0) > falsepulseDelay) { //reduce noise by debouncing IR signal
lastDebounceTime_0 = millis();
if(Direction==1){
counter[0]++;
if(Direction==-1){
counter[0]--;
void count_1(){
if ((millis() - lastDebounceTime_1) > falsepulseDelay) {
lastDebounceTime_1 = millis();
if(Direction==1){
counter[1]++;
if(Direction==-1){
counter[1]--;
It's driving, in this, two outputs on an XY-160D motor controller.
The pinouts don't match the code, as I've been moving pins around, although, I'ver read that most pins can be used. I'm guessing it's just my not knowing how the interrupts should should be assigned on the Giga.
