Hey, I'm trying to use the following code to measure the RPM using a KY-024 sensor on my Arduino UNO. I try to count the number of interrupts (revolutions) in a 1000ms delay and calculate the RPM. However, when the interrupt is called, the 'delay(1000)' step (in the loop section!) seems to be skipped and I get erratic results. It seems that the progamme doesn't wait anymore and executes the 'loop' everytime the magnet is sensed/interupt is called.
May be something all too simple..please be gentle, i'm a newbie
Also note that I used a IR sensor module in the same way and with the same code; it worked perfectly. Problem with that was that daylight messed up the working of the IR. I rather want to use the Hall sensor.
Thanx a lot!
The code:
#include <LiquidCrystal_I2C.h> // Library for LCD
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
volatile float revolutions=0;
int rpm=0; // max value 32,767 16 bit
long startTime=0;
long elapsedTime;
pinMode(3, INPUT_PULLUP); // set pin to input
lcd.init(); // initialize the lcd
lcd.backlight();
lcd.setCursor(0, 0); // move cursor to (0, 0)
lcd.print("Snelheid"); // print message at (0, 0)
lcd.setCursor(0, 1); // move cursor to (2, 1)
lcd.print("0");
attachInterrupt(digitalPinToInterrupt(3),interruptFunction,RISING);
revolutions=0;
rpm=0;
startTime=millis();
//detachInterrupt(3);
//now let's see how many counts we've had from the hall effect sensor and calc the RPM
elapsedTime=millis()-startTime; //finds the time, should be very close to 1 sec
if(revolutions>0)
rpm=(max(1, revolutions) * 60000) / elapsedTime; //calculates rpm
lcd.setCursor(0,0);
String outMsg = String("RPM :") + rpm;
//fillMessage2DisplayWidth(outMsg);
lcd.print(outMsg);
Serial.println(outMsg);
void interruptFunction() //interrupt service routine
revolutions++;
The sketch:
Sketch KY-024
Why is 'revolutions' a floating point type? Can you count fractional revolutions?
Well then, it's not likely to be a software problem then, is it? Please post a complete schematic and links to the hardware.
Hi, thnx for your answer. I agree and I changed to 'volatile int' but same problem.
Hi. I attached a link to the sketch in the orginal post. Or what do you mean?
Just to add the output of the serial monitor:
Post a diagram of your hardware connections and provide web links that provide information about the sensors you are using.
DO NOT post screen shots of code or printed output. Post text.
Thank you. Now please post your hardware diagram. Show us how you have connected it.
should be
rpm=(max(1, revolutions) * 60000L) / elapsedTime;
I'll come to back to you for that.
Okay, we'll wait for you to read the forum guidelines.
long startTime=0;
long elapsedTime;
should be
unsigned long startTime=0;
unsigned long elapsedTime;
I didn't test this code, I just verified that it compiles correctly.
Test and let us know if it meets your needs.
volatile long revolutions = 0;
int rpm = 0; // max value 32,767 16 bit
lcd.backlight();
lcd.print("0");
attachInterrupt(digitalPinToInterrupt(3), interruptFunction, RISING);
elapsedTime = millis(); // Init elapsedTime
if (millis() - elapsedTime >= 1000) // 1 seg passed?
cli(); // Disable interrupts
elapsedTime = millis(); // Recharge elapsedTime
rpm = (max(1, revolutions) * 60000L) / elapsedTime; //calculates rpm
revolutions = 0;
sei(); // Enable interrupts
lcd.print(outMsg);
revolutions++;
Because is the type of millis()
Oh, good catch. I was wondering what is the point of measuring delay(1000) each time through loop(). It's always going to be the same.
I think you could eliminate the whole millis() and time stamps and it wouldn't change the operation of the program.
It would be more appropriate to use millis() to trigger a measurement block every 1000ms., and eliminate the delay() completely.
HI. Thnx for your reply. No, it does still produce erratic results (including negative numbers for RPM, which puzzles me).
I found an error in the code I posted. Wait I'll fix it.
actually there were several errors in the code I posted. Sorry.
Test this one now.
unsigned long rpm = 0; // max value 64 bit
lcd.backlight();
lcd.print("0");
rpm = (max(1, revolutions) * 60L); //calculates rpm
revolutions = 0;
String outMsg = "RPM :" + String(rpm);
lcd.print(outMsg);
revolutions++;
Try this modification to your code
volatile unsigned long revolutions=0;
unsigned long rpm=0;
// unsigned long startTime=0;
// unsigned long elapsedTime;
pinMode(3, INPUT); // set pin to input
lcd.backlight();
lcd.print("0");
//attachInterrupt(digitalPinToInterrupt(3),interruptFunction,RISING);
revolutions=0;
rpm=0;
// startTime=millis();
detachInterrupt(digitalPinToInterrupt(3));
// invalid instruction corrected
// detachInterrupt(3);
// thanks @gonpezzi
// elapsedTime=millis()-startTime; //finds the time, should be very close to 1 sec
if(revolutions>0)
rpm = revolutions * 60UL; //calculates rpm
lcd.setCursor(0,0);
lcd.print(outMsg);
revolutions++;
