I am working on a project that will use arduino to control 8 printers. I have the wiring in mind but I am trying to program the task. So far I am using 8 LED's and the time they are on represent the time they will be printing. So I can get the lights to blink but i want to be able to stop the lights at any moment and restart from the same point. Currentlly I have to hold the button to eventually stop the loop.
I also know ther are better ways to write this code but I am really new at this. Please Help
int switchPin2 = 2;
int switchPin = 1;
int led1Pin = 13;
int led2Pin = 12;
int led3Pin = 11;
int led4Pin = 10;
int led5Pin = 9;
int led6Pin = 8;
int led7Pin = 7;
int led8Pin = 6;
int val;
int val2;
int buttonState;
int lightMode = 0;
pinMode(switchPin, INPUT);
pinMode(led1Pin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(led3Pin, OUTPUT);
pinMode(led4Pin, OUTPUT);
pinMode(led5Pin, OUTPUT);
pinMode(led6Pin, OUTPUT);
pinMode(led7Pin, OUTPUT);
pinMode(led8Pin, OUTPUT);
Serial.begin(9600); // Set up serial communication at 9600bps
buttonState = digitalRead(switchPin); // read the initial state
void loop(){
val = digitalRead(switchPin2); // read input value and store it in val
delay(50); // 10 milliseconds is a good amount of time
val2 = digitalRead(switchPin2); // read the input again to check for bounces
if (val == val2) { // make sure we got 2 consistant readings!
if (val != buttonState) { // the button state has changed!
if (val == LOW) { // check if the button is pressed
if (lightMode == 0) { // if its off
lightMode = 1; // turn lights on!
if (lightMode == 1) { // if its all-on
lightMode = 0; // make it blink!
if (lightMode == 2) { // if its blinking
lightMode = 3; // make it wave!
if (lightMode == 3){ // if its waving,
lightMode == 0; // turn light off!
buttonState = val; // save the new state in our variable
if (lightMode == 0) { // test done
digitalWrite(led1Pin, LOW);
digitalWrite(led2Pin, LOW);
digitalWrite(led3Pin, LOW);
digitalWrite(led4Pin, LOW);
digitalWrite(led5Pin, LOW);
digitalWrite(led6Pin, LOW);
digitalWrite(led7Pin, LOW);
digitalWrite(led8Pin, LOW);
delay(100);
if (lightMode == 1) { // "wave"
digitalWrite(led1Pin, HIGH);
digitalWrite(led3Pin, HIGH);
digitalWrite(led6Pin, HIGH);
digitalWrite(led4Pin, HIGH);
digitalWrite(led5Pin, HIGH);
digitalWrite(led7Pin, HIGH);
digitalWrite(led2Pin, HIGH);
digitalWrite(led8Pin, HIGH);
