This is my code:
TLI 493D_SerialPrint_stucked
#include "hall3d.h"
#include "interface.h"
#include <Arduino.h>
#include <Wire.h>
// enable Serial
while (!Serial);
// Init Sensor
// one bye read mode
// master contol mode
initSensor( );
sensorUpdata();
Serial.println(getX());
Serial.println((String)"Bx = " + getX());
Serial.println((String)"By = " + getY());
Serial.println((String)"Bz = " + getZ());
Serial.println((String)"Temp = " + getTemp());
Serial.print((String)"Angle = ");
Serial.println(getAngle());
and here is .h and .cpp file i used
hall3d.h
#ifndef __HALL3D_H__
#define __HALL3D_H__
#define SENSOR_IIC_ADDR TLI493D_A0
// Main Function & Struct
typedef struct _sensorData {
int16_t BX;
int16_t BY;
int16_t BZ;
int16_t TEMP;
} sensorData;
void initSensor ( void );
void sensorUpdata(void);
int16_t getX(void);
int16_t getY(void);
int16_t getZ(void);
int16_t getTemp(void);
float getAngle(void);
//TLI493D W2BW i2C slave device address(7bit format)
#define TLI493D_A0 0x35 //7 bit address format
#define TLI493D_A1 0x22 //7 bit address format
#define TLI493D_A2 0x78 //7 bit address format
#define TLI493D_A3 0x44 //7 bit address format
//TLI493D W2BW Power On/Off Control pin number
#define SensorPowerCtrlPin 5
#define INT_PIN 9
// Option. ๋ช๋ฒ์งธ ๋ ์ง์คํฐ๊น์ง ์ฝ์๋?
// 6 ==> X, Y, Z, Temp 7 ==> X, Y, Z, Temp and Diag
#define NumOfRdata 6
#define numOfReg 23 //0x00~0x16
//TLI493D reg inital setting
#define DT 0 //0 -> enable Temp(defualt), 1-> disable temp
#define AM 0 //0 -> measure Bx,y,z(Default) , 1-> measure Bx,y only
#define TRIG 2 //0 -> no ADC trig @ one-byte read mode (default)
//1 -> ADC trig before reading First MSB @ one-byte read mode
//2 -> ADC trig after reading reg 0x05(temp+bz) @ one-byte read mode
#define X2_sens 0
//#define X4_sens 0 //'00'-->[X2_sens:X4_sens]--> full range
//'10'-->[X2_sens:X4_sens]--> short range
//'11'-->[X2_sens:X4_sens]--> extra short range
#define TL_mag 1 // 0-> TC0 ( no temp compensation )
// 1-> TC2 ( temp compensation with TC1)
// 2-> TC3 ( temp compensation with TC2)
// 3-> TC4 ( temp compensation with TC3)
#define IICadr 0
// 0-> IIC addr 0x35 (equvalant product A0 type) (default)
// 1-> IIC addr 0x22 (equvalant product A1 type)
// 2-> IIC addr 0x78 (equvalant product A2 type)
// 3-> IIC addr 0x44 (equvalant product A3 type)
#define PR 1 // 0-> 2byte read mode (default)--> not allowed in this SW
// 1-> 1byte read mode
#define CA_INT 1 // 0-> INT endable but no interrupt during I2C communication (CA active)
// 1-> INT diable & Clock stetching enabled
// 2-> INT enable but there are possubilty inttrupt during i2c(CA not active )
// 3-> INT disble & Clock stetching disable (not recommended)
#define MODE 1 // 0-> LP mode (defalut)
// 1-> Master mode
// 2-> not allowed
// 3-> fast mode
#define PRD 0 // 0->fupdate โ 770 Hz (default)
// 1->fupdate โ 97 Hz
// 2->fupdate โ 24 Hz
// 3->fupdate โ 12 Hz
// 4->fupdate โ 6 Hz
// 5->fupdate โ 3 Hz
// 6->fupdate โ 0.4 Hz
// 7->fupdate โ 0.05 Hz
// Read sensor data struct
typedef struct _sensorConfigRegs {
uint8_t Dt;
uint8_t Am;
uint8_t Trig;
uint8_t x2_sens;
// uint8_t x4_sens;
uint8_t Tl_mag;
uint8_t iiCadr;
uint8_t Pr;
uint8_t Ca_int;
uint8_t Mode;
uint8_t Prd;
uint8_t WA; //Read only
uint8_t WU;
uint8_t TST;
uint8_t PH;
uint16_t XW;
uint16_t YW;
uint16_t ZW;
} sensorConfigRegs;
#endif
hall3d.cpp
#include "hall3d.h"
//#include <Wire.h>
//Internal function
//extern sensorConfigRegs sensorConfig;
void SimpleAssembleSensorData( sensorData * mag , uint8_t * sDATA );
void EnableOneByteReadOnly (void);
void PowerOn();
void WriteMirrorToSensorReg (void);
void sensorMirrorRegInit (void);
uint8_t CalParity( uint8_t * regData, uint8_t numByte);
void SensorRead(sensorData * mag, uint8_t numByte);
// Glrobal variable
sensorData mag;
volatile uint16_t sensorUpdated =0;
uint8_t senReg [numOfReg];
void magFieldReady_ISR (void);
void sensorMirrorRegInit (void){
sensorConfig.Dt=DT;
sensorConfig.Am= AM;
sensorConfig.Trig= TRIG;
sensorConfig.x2_sens= X2_sens;
// sensorConfig.x4_sens= X4_sens;
sensorConfig.Tl_mag= TL_mag;
sensorConfig.iiCadr= IICadr;
sensorConfig.Pr= PR;
sensorConfig.Ca_int= CA_INT;
sensorConfig.Mode= MODE;
sensorConfig.Prd= PRD ;
#define BX_R 0x00
#define BY_R 0x01
#define BZ_R 0x02
#define TEMP_R 0x03
#define BX2_R 0x04
#define TEMP2_R 0x05
#define DIAG_R 0x06 //Sensor diagnostic and status register
#define XL_R 0x07
#define YL_R 0x09
#define ZL_R 0x0B
#define XH_R 0x08
#define YH_R 0x0B
#define ZH_R 0x0C
#define WU_R 0x0D
#define TMODE_R 0x0E
#define TPHASE_R 0x0F
#define CONFIG_R 0x10 //Configuration register
#define MOD1_R 0x11 //Power mode, interrupt, address, parity
#define RSRV1_R 0x12 //reserved
#define MOD2_R 0x13 //Low Power Mode update rate
#define RSRV2_R 0x14 //reserved
#define RSRV3_R 0x15 //reserved
#define VER_R 0x16 //Version
// define bit positon of sensor reg
#define DT_bs 7
#define AM_bs 6
#define TRIG_bs 4
#define X2_sens_bs 3
//#define X4_sens_bs 0
#define TL_mag_bs 1
#define IICadr_bs 5
#define PR_bs 4
#define CA_INT_bs 2
#define MODE_bs 0
#define PRD_bs 5
//void EnableOneByteReadOnly (void){
// Wire.beginTransmission(SENSOR_IIC_ADDR);
// Wire.write(0x11); // Config, 0x10
// Wire.write(0b10011000); // MOD1 register, master controlled mode, one byte read command, enabled interrupt, no collision avoidance, odd FP parity
// Wire.endTransmission();
// Set REG to Known status without Fuse parity error for basic interface
// It is only for read interface
// It make One byte read mode , MASTER,Disable interrupt, Enable Clock steching
// after this, you should reconfig sensorConfig res which will be applied to your application
// FP should not be corrupted , no update on FP
//One byte, MASTER,Disable interrupt, Enable Clock steching ,PRD=0x00 with correct FP
uint8_t MOD1_PRD[3];
MOD1_PRD[0]=0x15;
MOD1_PRD[1]=0x38;
MOD1_PRD[2]=0x00;
(void) i2cWriteArray ( SENSOR_IIC_ADDR, MOD1_R , MOD1_PRD,3 );
void SimpleAssembleSensorData( sensorData * mag , uint8_t * sDATA ){
int16_t bx,by,bz,temp;
uint8_t diag,ubyte, parity;
sensorData HallData;
mag->BX=(int8_t) *(sDATA+0);
mag->BY=(int8_t) *(sDATA+1);
mag->BZ=(int8_t) *(sDATA+2);
mag->TEMP=(int8_t) *(sDATA+3);
ubyte=*(sDATA+4);
//assemble bx into int16
mag->BX=(mag->BX)<<4;
mag->BX=(mag->BX)|(ubyte>>4);
//assemble by into int16
mag->BY=(mag->BY)<<4;
mag->BY=(mag->BY)|(0x0F&ubyte);
//assemble bz into int16
ubyte=*(sDATA+5);
mag->BZ=(mag->BZ)<<4;
mag->BZ=(mag->BZ)|(0x0F&ubyte);
//assemble temp into int16
mag->TEMP=(mag->TEMP)<<4;
mag->TEMP=(mag->TEMP)|( 0x0C&(ubyte>>4) );
//DIAG byte
//mag->TEMP=*(sDATA+6);
// if ODD parity --> return 1
uint8_t CalParity( uint8_t * regData, uint8_t numByte){
uint8_t i,parity;
parity=*(regData+0);
for (i=1;i<numByte;i++)
parity^=*(regData+i);
parity ^= parity >> 4;
parity ^= parity >> 2;
parity ^= parity >> 1;
return (parity&0x01);
void SensorRead(sensorData * mag,uint8_t numByte ){
uint8_t reg[7];
(void)I2cRead(SENSOR_IIC_ADDR, reg, numByte);
SimpleAssembleSensorData( mag , reg );
void sensorUpdata(void){
SensorRead(&mag,7);
int16_t getX(void){
return mag.BX;
int16_t getY(void){
return mag.BY;
int16_t getZ(void){
return mag.BZ;
int16_t getTemp(void){
return mag.TEMP;
float getAngle(void){
float angle ;
angle = atan2(mag.BX, mag.BY)*180/PI;
return angle ;
void PowerOn(void){
pinMode(SensorPowerCtrlPin,OUTPUT);
digitalWrite(SensorPowerCtrlPin,HIGH);
delay(100);
digitalWrite(SensorPowerCtrlPin,LOW);
delay(50);
uint8_t updateCP (void){
uint8_t cpReg[10] ; //0x07~0x10
//copy
for (int16_t i =0 ; i< 10;i++){
cpReg[i]=senReg[0x07+i];
cpReg[6]= cpReg[6]&(~0x80); //bit[7] Clear in 0x0D reg
cpReg[7]= cpReg[7]&(~0xC0); //bit[7:6] Clear in 0x0E reg
cpReg[8]= cpReg[8]&(~0xC0); //bit[7:6] Clear in 0x0F reg
cpReg[9]= cpReg[9]&(~0x01); //bit[1] Clear in 0x10 reg
//return CalParity 1 if odd
if( CalParity( cpReg, 10) ) {
return 0x00;
} else{
return 0x01;
uint8_t updateFP (void){
uint8_t cpReg[2] ; //0x07~0x10
//copy
cpReg[0]=senReg[MOD1_R];
cpReg[1]=senReg[MOD2_R];
//bitclear
cpReg[0]= cpReg[0]&(~0x80); //bit[7] Clear in 0x11 reg
cpReg[1]= cpReg[1]&(~0x1F); //bit[7:5] Clear in 0x13 reg
// CalParity() return 1 if odd
if( CalParity( cpReg, 2) ) {
return 0x00;
} else{
return 0x80;
void initSensor ( void ) {
// Power on
// PowerOn();
// Init I2C
initI2C();
// enable One byte read interface
EnableOneByteReadOnly();
// update sensosrMirrorReg as default value
sensorMirrorRegInit();
// Write sensorMirrorReg to Sensor's real Register with correct parity bit
WriteMirrorToSensorReg();
// sensor measurement done ISR attach
//pinMode(INT_PIN, INPUT);
//attachInterrupt(digitalPinToInterrupt(INT_PIN),magFieldReady_ISR, FALLING);
void WriteMirrorToSensorReg (void){
// Copy sensor Register to senReg for CP calculation & block write
(void) I2cRead(SENSOR_IIC_ADDR,senReg,numOfReg);
//update Config & Mod1 & Mod2 & RSRV2 reg from sensorConfig value
senReg[CONFIG_R]=((sensorConfig.Dt)<<DT_bs)|((sensorConfig.Am)<<AM_bs)|((sensorConfig.Trig)<<TRIG_bs)|((sensorConfig.x2_sens)<<X2_sens_bs)|((sensorConfig.Tl_mag)<<TL_mag_bs);
senReg[MOD1_R]=((sensorConfig.iiCadr)<<IICadr_bs)|((sensorConfig.Pr)<<PR_bs)|((sensorConfig.Ca_int)<<CA_INT_bs)|((sensorConfig.Mode)<<MODE_bs);
senReg[MOD2_R]=(sensorConfig.Prd)<<PRD_bs;
//senReg[RSRV2_R]=(sensorConfig.x4_sens)<<X4_sens_bs;
// CP,FP update
senReg[CONFIG_R]= (senReg[CONFIG_R]&(~0x01))|updateCP();
senReg[MOD1_R]= (senReg[MOD1_R]&(~0x80))|updateFP();
// Write to sensor form config(0x10) upto Mod2(0x13) , RSRV2_R register
(void) i2cWriteArray ( TLI493D_A0, CONFIG_R, & (senReg[CONFIG_R]),4);
(void) I2CWrite ( TLI493D_A0, RSRV2_R, senReg[RSRV2_R]);
//void magFieldReady_ISR (void){
// sensorUpdated=1;
// if (sensorConfig.Mode!=1){ // if opreation mode is not MASTER mode)
// SensorRead(&mag,NumOfRdata);
interface.h
#ifndef __INTERFACE_H__
#define __INTERFACE_H__
#define II2C_BaudRate 400000
void initI2C (void);
uint8_t I2CWrite( uint8_t addr, uint8_t * wData, uint8_t wLength);
uint8_t I2cRead ( uint8_t i2cAddr, uint8_t * data, uint8_t len);
uint8_t i2cWriteArray ( uint8_t i2cAddr, uint8_t regAddr, uint8_t * data,uint8_t len );
#endif
interface.cpp
#include <Wire.h>
void initI2C(void) {
Wire.begin();
Wire.setClock(II2C_BaudRate);
uint8_t I2CWrite( uint8_t addr, uint8_t * wData, uint8_t wLength){
int i;
Wire.beginTransmission(addr);
for (i=0;i++;i< wLength){
Wire.write(*(wData+i));
uint8_t I2cRead ( uint8_t i2cAddr, uint8_t * data, uint8_t len){
uint8_t receivedBytes,i;
receivedBytes= Wire.requestFrom(i2cAddr, len); // request 2 bytes from slave device #112
if (receivedBytes == len)
for (i = 0; i < len; i++)
*(data+i) = Wire.read();
return receivedBytes;
uint8_t i2cWriteArray ( uint8_t i2cAddr, uint8_t regAddr, uint8_t * data,uint8_t len ){
uint8_t i;
//return
//0:success
//1:data too long to fit in transmit buffer
//2:received NACK on transmit of address
//3:received NACK on transmit of data
//4:other error
Wire.beginTransmission(i2cAddr); // send sensor start bit + sensor addr
Wire.write(0x20|regAddr); // ADC trigger after Write frame is finished
for (i=0;i<len;i++) {
Wire.write( *(data+i) );
return (Wire.endTransmission()); // stop transmitting
And Error message is just like this when I compile this file for board setting of "Arduino nano 33 BLE Sense"
sketch\hall3d.cpp: In function 'void WriteMirrorToSensorReg()':
hall3d.cpp:345:57: error: invalid conversion from 'int' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
In file included from sketch\hall3d.cpp:2:0:
sketch\interface.h:8:9: note: initializing argument 2 of 'uint8_t I2CWrite(uint8_t, uint8_t*, uint8_t)'
exit status 1
