Invalid Device Signature when using Arduino as ISP
Hi everyone – I’ve programmed for a while but I’m just getting into embedded programming and I’m following a book that uses avrdude with attiny85 but I keep getting a bad response when I try to setup my system.
Here’s the background on my system and what I’ve done so far:
  • Running windows 11
  • Installed avr-gcc and avrdude, both show correct versions when called from command line
  • Uploaded the Arduino ISP sketch to my Arduino Mega2560
  • Added 10uF cap from Arduino RESET to GND
  • ATTiny85 pin 1 → D10, pin 5 –> D11, pin 6 –> D12, pin 7 –> D13
  • D9 I’ve connected to a resistor and LED so that when the ISP program is running it slowly blinks
With that setup, I run the command:
avrdude -c arduino -p t85 -P COM3 -b 19200 -v
This is the output I get:
Avrdude version 8.0-20250112 (e3403b585)
Copyright see avrdude/AUTHORS at main · avrdudes/avrdude · GitHub
System wide configuration file is C:\tools\msys64\mingw64\etc\avrdude.conf
Using port : COM3
Using programmer : arduino
Setting baud rate : 19200
AVR part : ATtiny85
Programming modes : SPM, ISP, HVSP, debugWIRE
Programmer type : Arduino
Description : Arduino bootloader using STK500 v1 protocol
HW Version : 2
FW Version : 1.18
Topcard : Unknown
AVR device initialized and ready to accept instructions
Device signature = 00 00 00 (retrying)
Error: invalid device signature
Error: expected signature for ATtiny85 is 1E 93 0B. double check connections and try again, or use -F to carry on regardless
Avrdude done. Thank you.
I have verified that Arduino ISP sketch is 19200 baudrate
I have verified it is on COM3
The AT chip is new so I don’t see why it would be having clock issues
I also have two of the AT chips and tried both of them, so its not a chip failure
I have verified the wires are not loose
I have verified that AT is getting 5V
Any suggestions on what to try next?
Any help is appreciated. Please be kind – I’m new here.
Pins 10/11/12/13 are not the SPI pins on the Mega; check the Mega's schematic.
Thank you for your help. I’ve looked at the schematic and I’ve rewired it such that
AT pin 7 –> 52 (SCK), pin 5 → 51 (MOSI), pin 6 –> 50 (MISO). However, I was a bit confused about where AT pin 1 should go. I tried using D53 but that did not work however using D10 did work. Why is that? Thanks again for the help!
Pin 10 is used as used as the reset pin for the ATtiny and is coded in the ArduinoISP sketch
#define RESET 10  // Use pin 10 to reset the target rather than SS
