Invalid preprocessing directive #using
ok
is there an off the shelf solution or not?
I think we don't have enough information
as I said above
OP's description of the requirements is
I want to log Analog pin A0 to a text file pretty much so that it can be downloaded and you can see the info
so it could even be recorded in SPIFFS or similar on an ESP an be made available through a builtin web site or FTP-ed somewhere
tons of solutions :slight_smile:
So if I wanted to make a consumer panel where they could sign in and access the "Recordings", I could make it a website and have them sign in to see it?
Everything is (usually) possible - it just requires skills, work and resources.
step one is usually to start describing detailed requirements for the project. If you don't know where you want to go, you'll go nowhere... :slight_smile:
Ok, I want to do the website option, but I'm not sure how. Is there another fourm or a video that you know of that shows how to do this. I have a plan in mind and how to code the website I just need to know how to integrate it.
you could have a look there for an ESP32
https://diyprojects.io/esp32-get-started-spiff-library-read-write-modify-files/#.YOYEWi2FDVs
