arduino IDE 1.x, 2.x
Board Manager : Arduino UNO R4 Boards 1.0.2
File -> example -> UNO R4 xxx example -> AnalogWave -> SineWave
#include "analogWave.h"
analogWave wave(DAC);
int freq = 10; // in hertz, change accordingly
pinMode(A0, INPUT);
wave.sine(freq);
freq = map(analogRead(A0), 0, 1024, 0, 10000);
Serial.println("Frequency is now " + String(freq) + " hz");
wave.freq(freq);
This example code outputs the signal received with A0 to DAC.
But A0 is a DAC pin.
Web page examples use A5 instead of A0.
the same example
https://docs.arduino.cc/tutorials/uno-r4-minima/dac
The example seems to be invalid.
Thanks for bringing this to our attention @nyk_yeon . A fix for the example is now in progress:
arduino:main ← jacobhylen:jacobhylen/dac-analogwave-fix
opened 12:43PM - 18 Jul 23 UTC
SineWave example of the AnalogWave library was using A0 as an input pin, but the… A0 pin is the DAC output pin.
https://forum.arduino.cc/t/invalid-r4-sinewave-ino-example/1149139
This PR changes the potentiometer input pin to A5, to match the other DAC examples in the library.
Just change A0 to A5 and it will work! It appears twice in the code, you need to change both instances.
I came up with this simple fix and it worked.
* Generate a sin wave with frequency
* determined with a pot on A1
* Wave output on A0
int freq = 1000; // in hertz, change accordingly
pinMode(A1, INPUT);
wave.sine(freq);
freq = map(analogRead(A1), 0, 1024, 0, 10000);
wave.freq(freq);
Hello everybody !
to generate a frequency i use this code from 5Hz to 10kHz
* Wave output on A0
int freq = 2000; // in hertz, change accordingly
wave.sine(freq);
wave.freq(freq);
