Iam making a project about led control with Ultrasonic and a virtual slider from arduino ioT cloud. iam using a virtual swtich (on/off) from arduino IoT cloud as the logic changer. when the switch is on i want the led is controlled by ultrasonic, where the distance <= 80 turn on lamp1 and if not would turn it off, but when the virtual switch is off i want the lamp1 is no longer controlled by ultrasonic, instead by a slider (using PWM). but what happens is when i turn on the swtich, lamp1 doesn't change it's state even the distance is > 80, but when the switch is off, lamp1 can be controlled by the slider, here's my code :
#define trig 8
#define echo 7
#define lamp1 11
delay(1500);
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
pinMode(lamp1, OUTPUT);
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
if (lED) {
// Jika switch ON, kontrol lamp1 menggunakan jarak ultrasonik
controlWithUltrasonic();
// Jika switch OFF, kontrol lamp1 menggunakan slider dim
analogWrite(lamp1, dim);
delay(100); // Delay untuk menghindari pembaruan terlalu cepat
void controlWithUltrasonic() {
// Mengambil pembacaan jarak dari sensor ultrasonik
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
long duration = pulseIn(echo, HIGH);
distance = duration / 29 / 2;
// Mengatur lamp1 berdasarkan jarak ultrasonik
if (distance <= 80) {
digitalWrite(lamp1, HIGH);
digitalWrite(lamp1, LOW);
void onLEDChange() {
// Jika switch berubah ke ON atau OFF, panggil mode kontrol yang sesuai
if (lED) {
controlWithUltrasonic(); // Mulai kontrol dengan ultrasonik
analogWrite(lamp1, dim); // Mulai kontrol dengan slider
void onDimChange() {
// Perbarui lamp1 dengan nilai slider hanya jika lED dalam posisi OFF
if (!lED) {
ketik atau tempel kode di sini
