Hello, I'm new to this and having trouble creating a code for IOT could.
So on the dashboard, you have a Stepper Widget and a Dimmed Light Widget.
The problem is the I need to use the Stepper Widget but it does not work with Alexa, but the Dimmed light Widget does. How do I create a code where it will allow the Stepper Widget match the Dimmed Light brightness code. So as I change the light brightness, that number will be digitalWrite to the Stepper Widget and back. A
nd the on/off will control the status LED
