IoT Fails to connect
I am getting this error after uploading my sketch to ESP 8266, while trying to connect.
ArduinoIoTCloudTCP::handle_ConnectMqttBroker could not connect to mqtts-up.iot.arduino.cc:8884
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 1 connection attempt at tick time 11396
Any helps is much appreciated in advance.
You can check these threads
I hope your problem will be solved if you follow the discussions of the above links. Here is a good IoT project idea using ESP8266.
