IoT Relay - Can I monitor power?
Greetings:
I have the following IoT Relay from (iotrelay.com). I will be using an Arduino Uno R3 to control the relay. My Arduino will have a battery power source. My ultimate goal is to use the Arduino and this relay to create a slight delay in powering on a device following a power outage. Can I monitor incoming power to the relay using an Arduino? I understand how to switch the device off and on with the Arduino, but the monitoring of the power is the critical step in the problem I am trying to solve.
Please note that I am a beginner, so any plain-language guidance would be greatly appreciated.
Thanks!
You can plug a 5v USB POWER module into your AC.
When there is AC power, there will be 5v on the output of this module.
No AC, module voltage is 0v.
Ok, that makes sense — thank you!
