IR Receiver Continously running
I have made a code that takes in inputs from the IR remote then turns the motors a certain way. All of my buttons work properly but once I press a button once. It runs that over and over again and I can't input another signal. All of the lights on my board flicker like its getting the IR signal a bunch of times. I'll post the code below. I suspect its not breaking the loop but I have no idea how to fix it. Thanks!
#include <IRremote.hpp>
#define IR_RECEIVE_PIN 11
const int PWM_M1 = 5;
const int IN1_M1 = 2;
const int IN2_M1 = 3;
const int PWM_M2 = 6;
const int IN1_M2 = 8;
const int IN2_M2 = 9;
int speed = 100;
// Function prototype
void stop();
  IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK); // Initialize IR receiver
  pinMode(PWM_M1, OUTPUT);
  pinMode(PWM_M2, OUTPUT);
  pinMode(IN1_M1, OUTPUT);
  pinMode(IN2_M1, OUTPUT);
  pinMode(IN1_M2, OUTPUT);
  pinMode(IN2_M2, OUTPUT);
  // Check if IR data is available
  if (IrReceiver.decode()) {
    // Handle the decoded IR signal
    unsigned long irData = IrReceiver.decodedIRData.decodedRawData;
    Serial.print("Received IR code: ");
    Serial.println(irData, HEX);
    // Switch based on received IR code
    switch (irData) {
      case 0x1BA45FF00:  // power
        break;  // No action for this IR code
      case 0x2B946FF00:  // VOL+
        forward();
      case 0x3B847FF00:  // FUNC/STOP
        stop();
      case 0x4BB44FF00:  // |<<
        turnLeft();
      case 0x5BF40FF00:  // >||
        stop();
      case 0x6BC43FF00:  // >>|
        turnRight();
      case 0x8EA15FF00:  // VOL-
        backward();
      default:
        Serial.println("Unknown IR code");
    // Ready to receive the next signal
   IrReceiver.resume();
void forward() {
  Serial.println("Moving forward");
  analogWrite(PWM_M1, 255);
  analogWrite(PWM_M2, 225);
  digitalWrite(IN1_M1, HIGH);
  digitalWrite(IN2_M1, LOW);
  digitalWrite(IN1_M2, HIGH);
  digitalWrite(IN2_M2, LOW);
void backward() {
  Serial.println("Moving backward");
  analogWrite(PWM_M1, 225);
  digitalWrite(IN1_M1, LOW);
  digitalWrite(IN2_M1, HIGH);
  digitalWrite(IN1_M2, LOW);
  digitalWrite(IN2_M2, HIGH);
void turnLeft() {
  Serial.println("Turning left");
  analogWrite(PWM_M1, 0);
void turnRight() {
  Serial.println("Turning right");
  analogWrite(PWM_M2, 0);
void stop() {
  Serial.println("Stopping motors");
Here is a screenshot of my wiring diagram
If you are using classic arduino board, you can't use pin3 for analogwrite.
Or you have to turn receiver off before you use pin3.
Ok, switched the pins but its still running continuously. In my serial monitor, it is constantly running and giving me random hex codes. So I still cant stop the motors.
The posted sketch does not use pin 3 with analogWrite() but in any case it is perfectly valid to do so
  • Do not power motors with your Arduino. :grimacing:
You are right. Op was using digitalwrite. My mistake.
What else should I use then?
