I've hijacked a program that works with the IR receiver, i wanted to try using a different remote control. It's working for every second press of the button, no matter how long i wait between pressing the button. Any idea why, code below. Thanks.
//www.elegoo.com
//2016.12.9
#include "IRremote.h"
int receiver = 11; // Signal Pin of IR receiver to Arduino Digital Pin 11
/*-----( Declare objects )-----*/
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
/*-----( Function )-----*/
void translateIR() // takes action based on IR code received
int x = results.value;
//I used the following line to find what the value the remote returned
//Serial.println(x);
if(x == 262) {Serial.println("1");}
if(x == 277) {Serial.println("2");}
if(x == 285) {Serial.println("3");}
if(x == 293) {Serial.println("4");}
if(x == 270) {Serial.println("5");}
if(x == 278) {Serial.println("6");}
if(x == 286) {Serial.println("7");}
if(x == 294) {Serial.println("8");}
if(x == 263) {Serial.println("9");}
delay(500); // Do not get immediate repeat
Serial.println("IR Receiver Button Decode");
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) // have we received an IR signal?
translateIR();
irrecv.resume(); // receive the next value
