IR remote to control 1 servo
hi
I have been trying to control a servo to go to 100little circle when i press the + button on my remote but it won't work :frowning:
here is my code
/code/
Some Sample code of how to use your IR remote
  • Lets get started:
The IR sensor's pins are attached to Arduino as so:
Pin 1 to Vout (pin 11 on Arduino)
Pin 2 to GND
Pin 3 to Vcc (+5v from Arduino)
#include <IRremote.h>
#include <Servo.h>
int IRpin = 11; // pin for the IR sensor
int pos = 100;
IRrecv irrecv(IRpin);
decode_results results;
Servo myservo;
irrecv.enableIRIn(); // Start the receiver
myservo.attach(9);
if (irrecv.decode(&results))
Serial.println(results.value, DEC);
irrecv.resume(); // Receive the next value
if (results.value == 16754775) // change zero to your IR remote button number
myservo.write(pos);
delay(15);
/code/
is it my coding skills or something else.
servo = pin 9
IR = pin 11
Have you confirmed that the IR signal received is the value you have coded?
Weedpharma
try this
       myservo.write(pos);
       delay(15);
note you dont seem to be changing the value of pos !!
thanks
im a noob
the servo dose not want to turn I'm getting these values
16754775
4294967295
what did you mean by changing the value of pos?
oh now i get it
i know all i want is to get it to go to 100little circle
