IR send difficulty
Hi there,
I have an arduino uno and I have successfully collected the IR codes from my tv and controlled it with an IR LED according to my desire. I have not been able to do the same on my Pioneer receiver however. I have the codes and the proper formatting hoever i am not getting any action. I know that on the Sony Tv's they require 3 sends to register a signal to complete an action. Does anybody know what might be causing the issue? i am using the NEC formatting on a receiver (VSX 823K). Are there any quirks that i need to keep in mind when dealing with this different brand? The sony seemed to work just fine. I have posted the code below.
Thanks for your help,
John
#include <IRremote.h>
IRsend irsend;
if (Serial.read() != -1) {
for (int i = 0; i < 3; i++) {
irsend.sendSony(0xA55AD02F, 32); // Receiver Volume Down
delay(100);
Hi
I am still new to this but believe you need to change your send command from ir.sendSony to ir.sendNEC
I don't think NEC codes need to be sent 3 times like the Sony codes so you should be able to remove your "for" loop and just have the below line in the "loop()" section of your code:
irsend.sendNEC(0xA55AD02F, 32);// Receiver Volume Down
