IR sensor giving 0xFFFFFF code only
Hi, I started working on IR sensors recently and I typed up this basic code using the IR_Remote library by shirriff:
const int RECV = 4;
IRrecv irrecv(RECV);
decode_results results;
  irrecv.enableIRIn();
  if(irrecv.decode(&results)){
    Serial.println(results.value, HEX);
    irrecv.resume();
I started pressing buttons on the remote that comes with the starter kit (rexquails), it follows the NEC protocol. for some reason, I only get the code 0xFFFFFFFF for every single button I press. I know that that is the repeat code, but shouldn't there be a different one before the f's start? I am trying to get all of the hex codes for all of the buttons on the remote. Here is it's picture:
The library has changed, check the current examples.
I update your example:
#include <IRremote.hpp>
const int RECV = 4;
//decode_results results;  // deprecated
  if(irrecv.decode()){
    Serial.println(irrecv.decodedIRData.decodedRawData, HEX);
    irrecv.resume();
