IR serial connection
I'm trying to send and receive ir via an Arduino, this is my code + schematic
#include <SoftwareSerial.h>
#define IR_RX 8
#define IR_TX 9
#define IR_CARRIER_PIN 3
SoftwareSerial IR(IR_RX, IR_TX);
  IR.begin(4800);
  tone(IR_CARRIER_PIN, 30000);
  Serial.begin(19200);
  Serial.println("Hello, world!");
  if(Serial.available()){
    while(Serial.available()) {
      IR.write(Serial.read());
  if(IR.available()) {
    while(IR.available()) {
      Serial.println("Data:");
      Serial.println(IR.read());
I'm not receiving anything on the receiving Arduino, can someone explain why?
Do you really not have a current limiting resistor in series with your IR LED?
You may be able to check if the IR LED is working by using a mobile phone camera. Test the camera first on a TV remote to make sure that it has no IR filter, then see if you can pick anything up from your LED.
You don't need the if statement since the while is making the same test.
We have a FET driving the IR led. Along with a current limiting resistor. These are not shown in the diagram. We've filmed the IR led. It blinks briefly when transmitting. We've scoped pin 3. It shows a 30khz square wave. We've scoped pin 9. It shows serial data being transmitted.
LuluTheCoffeeAddict:
What does Pin 8 show?
Not much point in posting a schematic if it is not correct.
And what about pin 8? Anything detectable happening there?
Pin 8 on the receiving arduino shows nothing
Ok, we'll assume the sensor is not broken.
Try a lower Baud for the sensor - 2400 or less. Check again with the scope for any action.
Turns out the wires on the receiving arduino were connected to the wrong pins, I reconnected them and I am now receiving data. Sadly the bytes I'm receiving are all 255
Your original (seemingly unrepresentative) schematic only shows 1 Arduino?
Did you miss-wire the sensor or what? Because I would have thought you would have seen something on the scope even if pin 8 was connected to a wrong Arduino pin.
Please post an accurate schematic.
This IR Serial Thread may be of interest.
...R
