I get this error message when I try to compile the code;
c:\Program Files\Arduino\libraries\RobotIRremote\scr\IRremotetools.cpp:5:16: error: 'TKD2' was not declared in scope
int RECV_PIN = TKD2; // the pin the ir receiver is connected to
Any help would be most appreciated. I am new at this but trying.
I am trying to control a servo with the remote control that came in the kit.
Thanks
unsigned long Value1 = 0xFFA25D; // where XXXXXXXX is on our your remote's values
unsigned long Value2 = 0xFF629D; // where XXXXXXXX is another button on your remote
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
Servo servo1;
// the setup routine runs once when you press reset:
irrecv.enableIRIn(); // Start the receiver
// initialize the digital pin as an output.
servo1.attach(10); // attack servo to digital pin 10
// the loop routine runs over and over again forever:
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
How can I get rid of this "RobotIRremote" folder. When I open libraries the folder does not seem to exist.
But if I open sketches-libraries-I find it, but can not delete it...
Any sugestions?
Sorry but for some reason I can not get this to work. I have unzipped the IR files into the libraries folder and the sketch still does not work.
Any suggestions?
I am happy to say that after several hours of playing, I finally got my IR remote to operate the servo/
The problem was the library not having the right IR information.
I was not loading the correct IR library into the program.
With the help of you all here, I was able to figure out how to do this, then it worked.
I am new to this and I do thank you for your help.
IT is going to be an interesting hobby!
