I have been trying to get an Infrared Receiver and Transmitter to work using Ken Shirriff’s IRremote Library.
I can get the receiver to read the infrared signals from my tv remotes but I cannot get the transmitters to send.
I don’t believe any signal is going to the transmitter at all as when I use my phone’s camera to view the LED I see no reaction.
I have also tried the simple Blink example in Arduino.
Below is a photo of my circuit:
I have three Uno boards and one Mega. I have three transmitter modules and the LED in the image. I have tried every tutorial and reference I could find on the internet. I have tried every example in the IRremote Library.
Nothing seems to work.
Any advice or help would greatly appreciated as I have been trying to get this to work for months.
FYI: I am an experienced programmer, so you can use all the jargon you want for that side of things, but I am still learning the circuitry side of things, so you will probably need to dumb it down for me.
You can do a number of things to check your circuit.
Measure the voltage across the current limiting resistor while running the blink program. You should see the voltage varing between 0V and about 3,5V
You can use a digital camera to check whether the diode emits ir light
You can exchange the Ir led for a red one to verify if it works
If any of these steps fails recheck you circuit. Make sure that you use the right pins and that you have a closed circuit. Also make sure you have the polarity right for the led.
Boffin1 reported he had picked up some LEDs at a very good price - didn't work until he discovered the lead lengths were backwards from normal. Supplier told him they were reverse polarity .
can you connect the IR LED and resistor across the 5V and gnd to see if you can detect it in your camera, just to verify that it is OK.
Also measure the voltage across the 220 resistor again.
Try with LED in both ways.
TomGeorge:
Tom...
I tried your suggestion and still no luck.
I tried to measure the resistor but all I got was 0.
