Hello All!
I have one base code:
#include <Servo.h>
//servo 1
Servo myservo;
Servo myservo1;
int s1a = 45; //closed R
int s1b = 165; //open R
int s2a = 45; //open L
int s2b = 165; //close Lint val; // variable for reading the pin status
int val2; // variable for reading the delayed/debounced status
int buttonState;
int pos = (s1a);
int pos1 = (s2b);
int servostatus = 0;
int switchPin =2; // Switch connected to digital pin 2
int ledPin = 5;void setup() // run once, when the sketch starts
//servo 1myservo.attach(9);
myservo1.attach(10);
pinMode(switchPin, INPUT);
pinMode(ledPin, OUTPUT);
buttonState = digitalRead(switchPin);
myservo.write(s1b);
myservo1.write(s2a);
}void loop() // run over and over again
//servo 1
val = digitalRead(switchPin); // read input value and store it in val
delay(10); // 10 milliseconds is a good amount of time
val2 = digitalRead(switchPin); // read the input again to check for bounces
if (val == val2) { // make sure we got 2 consistant readings!
if (val != buttonState) { // the button state has changed!
if (val == LOW) { // check if the button is pressed
if (servostatus == 0) { // is the light off?
servostatus = 1; // turn light on!myservo.write(s1a);
myservo1.write(s2b);
digitalWrite(ledPin, HIGH);
delay(50);
digitalWrite(ledPin, LOW);
delay(00);
delay(50);
delay(00);// fading
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
// sets the value (range from 0 to 255):
analogWrite(ledPin, fadeValue);
delay(30);}
servostatus = 0; // turn light off!digitalWrite(ledPin, LOW);
delay(15);myservo.write(s1b);
myservo1.write(s2a);}
buttonState = val; // save the new state in our variable
And attached scheme.
I would like to combine this code with DFPlayer mini.
At the opening of the faceplate it have to play sound 0001.mp3 & at closing it have to play 0002.mp3
Can anyone help me in this situation? So, to write the code and to complete the scheme.
Thanks in advance.
