ive wired up the helmet opening and close work great along with the eyes, so ive added the sound board but soon as it powers up it constantly plays the same 3 tracks over and over. im very new to the world of arduinos so hopefully something simple and a greater mind can point me in the direction of solving this. thank you for any help.
// Uncomment this line to enable sound for the S.U.E. expansion board
#define SOUND
// Referenced libraries
#include <VarSpeedServo.h>
#include <Bounce2.h>
#include <ButtonEvents.h>
#ifdef SOUND
// See: https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299#target_6
// Important!!! On the SD card copy the mp3 files into an mp3 directory
// Download and install the DFRobotDFPlayerMini library
#include <DFRobotDFPlayerMini.h>
#include <SoftwareSerial.h>
void printDetail(uint8_t type, int value); // header method for implementation below; affects C++ compilers
#endif
// Declare pin settings
const int servo1Pin = 9; // set the pin for servo 1
const int servo2Pin = 10; // set the pin for servo 2
const int buttonPin = 2; // the pin that the pushbutton is attached to
// led control pins (need to be PWM enabled pins for fading)
const int leftEyePin = 6; // left eye LEDs
const int rightEyePin = 3; // right eye LEDs
const int AuxLED = 4; // Aux LED non-PWM
#ifdef SOUND
// sound board pins
const int rx_pin = 7; // set pin for receive (RX) communications
const int tx_pin = 8; // set pin for transmit (TX) communications
#endif
// Declare servo objects
VarSpeedServo servo1; // create servo object to control servo 1
VarSpeedServo servo2; // create servo object to control servo 2
// Declare variables for servo control
const int servoCloseSpeed = 150; // set the speed of the servo close function
const int servoOpenSpeed = 255; // set the speed of the servo opening recommend set to max speed to aid in lift
// In Dual Servo Configuration the servos move in opposing directions, so the angles of the servos will be opposite to each other.
// Normal Servo range is 0° ~ 180°, for initial setup the range has been adjusted to 20° ~ 160°, this allows for a 20° adjustment at both ends of the servo range.
// See Helmet tutorial for further information on servo setup.
const int servo1_OpenPos = 30; // set the open position of servo 1
const int servo2_OpenPos = 148; // set the open position of servo 2
const int servo1_ClosePos = 152; // set the closed position of servo 1
const int servo2_ClosePos = 28; // set the closed position of servo 2
// Declare variables for button control
boolean movieblinkOnSetup = true; //Blink LEDs on setup, Sequence based on Avengers Movie
boolean movieblinkOnClose = true; //Blink LEDs on close of faceplate, Sequence based on Avengers Movie
// Declare variables for LED control
unsigned long fadeDelay = .1; //speed of the eye 'fade'
unsigned long callDelay = 10; //length to wait to start eye flicker after face plate comes down
unsigned long blinkSpeed = 60; //delay between init blink on/off
unsigned long currentPWM = 0; // keep track of where the current PWM level is at
boolean isOpen = true; // keep track of whether or not the faceplate is open
#ifdef SOUND
// Declare variables for sound control
const int volume = 20; // sound board volume level (30 is max)
#define SND_CLOSE 1 // sound track for helmet closing sound
#define SND_JARVIS 2 // sound track for JARVIS sound
#define SND_OPEN 3 // sound track for helmet opening sound
SoftwareSerial serialObj(rx_pin, tx_pin); // Create object for serial communications
DFRobotDFPlayerMini mp3Obj; // Create object for DFPlayer Mini
#endif
// Define object for primary button to handle
// multiple button press features:
// 1. Single Tap
// 2. Double Tap
// 3. Long Press
ButtonEvents primaryButton = ButtonEvents();
// State of the faceplate 1 = open, 0 = closed
#define FACEPLATE_CLOSED 0
#define FACEPLATE_OPEN 1
int facePlateCurMode = FACEPLATE_OPEN; // Keep track if the faceplate is open or closed
// State of the LED eyes 1 = on, 2 = off
#define LED_EYES_OFF 0
#define LED_EYES_ON 1
// State of the LED eyes for dimming/brightening 1 = brighten, 2 = dim
#define LED_EYES_DIM_MODE 0
#define LED_EYES_BRIGHTEN_MODE 1
int ledEyesCurMode = LED_EYES_DIM_MODE; // Keep track if we're dimming or brightening
int ledEyesCurPwm = 0; // Tracking the level of the LED eyes for dim/brighten feature
const int ledEyesIncrement = 15; // Define the increments to brighten or dim the LED eyes
* Helper Method
* Simulate a delay in processing without disabling the processor completely
* @param[out] period - the amount of time in milliseconds to delay
* See: https://randomnerdtutorials.com/why-you-shouldnt-always-use-the-arduino-delay-function/
void simDelay(long period){
long delayMillis = millis() + period;
while (millis() <= delayMillis)
int x = 0; // dummy variable, does nothing
* Simulate the eyes slowly blinking until fully lit
void movieblink(){
Serial.println("Start Movie Blink..");
// pause for effect...
simDelay(300);
int lowValue = 21;
int delayInterval[] = { 210, 126, 84 };
int delayVal = 0;
// First blink on
for (int i = 0; i <= lowValue; i++){
setLedEyes(i);
digitalWrite(AuxLED, LOW);
delayVal = delayInterval[0]/lowValue;
simDelay(delayVal);
// Turn off
setLedEyes(0);
digitalWrite(AuxLED, HIGH);
simDelay(delayInterval[0]);
// Second blink on
setLedEyes(i);
delayVal = delayInterval[1]/lowValue;
simDelay(delayVal);
// Turn off
setLedEyes(0);
simDelay(delayInterval[1]);
// Third blink on
setLedEyes(lowValue);
simDelay(delayInterval[2]);
// Turn off
setLedEyes(0);
// All on
setLedEyes(255);
#ifdef SOUND
* Initialization method for DFPlayer Mini board
void init_player(){
serialObj.begin(9600);
//simDelay(1000); Adjusting Timing Sequence
if(!serialObj.available()){
Serial.println("Serial object not available.");
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
bool dfInit = mp3Obj.begin(serialObj, false, true);
simDelay(1000);
if(!dfInit){
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
simDelay(400); // originally 1000ms
Serial.println(F("DFPlayer Mini online."));
mp3Obj.setTimeOut(500); //Set serial communictaion time out 500ms
Serial.println("Setting volume");
mp3Obj.volume(volume);
mp3Obj.EQ(DFPLAYER_EQ_NORMAL);
mp3Obj.outputDevice(DFPLAYER_DEVICE_SD);
* Method to play the sound effect for a specified feature
void playSoundEffect(int soundEffect){
Serial.print("Playing sound effect: ");
Serial.println(soundEffect);
mp3Obj.play(soundEffect);
printDetail(mp3Obj.readType(), mp3Obj.read()); //Print the detail message from DFPlayer to handle different errors and states.
#endif
* Method to open face plate
void facePlateOpen(){
Serial.println("Servo Up!");
// Re-attach the servos to their pins
servo1.attach(servo1Pin);
servo2.attach(servo2Pin);
// Send data to the servos for movement
servo1.write(servo1_OpenPos, servoOpenSpeed);
servo2.write(servo2_OpenPos, servoOpenSpeed);
simDelay(1000); // wait doesn't wait long enough for servos to fully complete...
// Detach so motors don't "idle"
servo1.detach();
servo2.detach();
* Method to close face plate
void facePlateClose(){
Serial.println("Servo Down");
servo1.write(servo1_ClosePos, servoCloseSpeed);
servo2.write(servo2_ClosePos, servoCloseSpeed);
servo1.detach();
servo2.detach();
facePlateCurMode = FACEPLATE_CLOSED;
* Set the brightness of the LED eyes
* @param[out] pwmValue - the PWM value (0-255) for the LED brightness
void setLedEyes(int pwmValue){
analogWrite(rightEyePin, pwmValue);
analogWrite(leftEyePin, pwmValue);
ledEyesCurPwm = pwmValue;
* Method to turn on LED eyes
void ledEyesOn(){
Serial.println("Turning LED eyes on...");
setLedEyes(255);
* Method to turn off LED eyes
void ledEyesOff(){
Serial.println("Turning LED eyes off...");
setLedEyes(0);
ledEyesCurMode = LED_EYES_BRIGHTEN_MODE;
* Method to turn LED eyes on/off
void ledEyesOnOff(){
// LED eyes stay off when faceplate is open
if(facePlateCurMode == FACEPLATE_CLOSED){
if (ledEyesCurPwm > 0){
ledEyesOff();
ledEyesOn();
void ledEyesDim(){
Serial.println("Dimming LED eyes...");
ledEyesCurPwm = ledEyesCurPwm - ledEyesIncrement; // Decrease the brightness
// Make sure we don't go over the limit
if(ledEyesCurPwm <= 0){
ledEyesCurPwm = 0;
void ledEyesBrighten(){
Serial.println("Brightening LED eyes...");
ledEyesCurPwm = ledEyesCurPwm + ledEyesIncrement; // Increase the brightness
if(ledEyesCurPwm >= 255){
ledEyesCurPwm = 255;
* Method to dim or brighten both LED eyes
void ledEyesFade(){
if(ledEyesCurPwm == 255){
} else if(ledEyesCurPwm == 0){
if(ledEyesCurMode == LED_EYES_BRIGHTEN_MODE){
ledEyesBrighten();
ledEyesDim();
setLedEyes(ledEyesCurPwm);
simDelay(200);
* Method to run sequence of sppecial effects when system first starts or sets up
void startupFx(){
//facePlateClose();
#ifdef SOUND
playSoundEffect(SND_CLOSE);
simDelay(500); // Timing for Helmet Close Sound and delay to servo closing
#endif
facePlateClose();
if(movieblinkOnSetup){
movieblink();
ledEyesOn();
#ifdef SOUND
simDelay(800); // Originally 2000ms
playSoundEffect(SND_JARVIS);
#endif
* Method to execute special effects when the faceplate opens
void facePlateOpenFx(){
// TODO: See if we need delays in between fx
#ifdef SOUND
playSoundEffect(SND_OPEN);
#endif
ledEyesOff();
facePlateOpen();
* Method to execute special effects when the faceplate closes
void facePlateCloseFx(){
//facePlateClose();
//simDelay(100); //Originally 1000ms
#ifdef SOUND
simDelay(1200); //Timing for Helmet Close Sound and delay to servo closing
#endif
facePlateClose();
if(movieblinkOnClose){
movieblink();
ledEyesOn();
* Handle faceplate special effects
void facePlateFx(){
if (facePlateCurMode == FACEPLATE_OPEN){
facePlateCloseFx();
facePlateOpenFx();
* Event handler for when the primary button is tapped once
void handlePrimaryButtonSingleTap(){
facePlateFx();
* Event handler for when the primary button is double tapped
void handlePrimaryButtonDoubleTap(){
ledEyesOnOff();
* Event handler for when the primary button is pressed and held
void handlePrimaryButtonLongPress(){
while(!primaryButton.update()){
ledEyesFade(); // Dim or brighten the LED eyes
* Initializes the primary button for multi-functions
void initPrimaryButton(){
// Attach the button to the pin on the board
primaryButton.attach(buttonPin, INPUT_PULLUP);
// Initialize button features...
primaryButton.activeLow();
primaryButton.debounceTime(15);
primaryButton.doubleTapTime(250);
primaryButton.holdTime(2000);
* Monitor for when the primary button is pushed
void monitorPrimaryButton(){
bool changed = primaryButton.update();
// Was the button pushed?
if (changed){
int event = primaryButton.event(); // Get how the button was pushed
switch(event){
case(tap):
Serial.println("Primary button single press...");
handlePrimaryButtonSingleTap();
case (doubleTap):
Serial.println("Primary button double press...");
handlePrimaryButtonDoubleTap();
case (hold):
Serial.println("Primary button long press...");
handlePrimaryButtonLongPress();
* Initialization method called by the Arduino library when the board boots up
// Set up serial port
simDelay(2000); // Give the serial service time to initialize
#ifdef SOUND
init_player(); // initializes the sound player
#endif
initPrimaryButton(); // initialize the primary button
pinMode(AuxLED, OUTPUT); // set output for AUX LED
startupFx(); // Run the initial features
* Main program exeucution
* This method will run perpetually on the board
monitorPrimaryButton(); // Since all features currently are tied to the one button...
// Room for future features ;)
#ifdef SOUND
* Method to output any issues with the DFPlayer
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
#endif/
