Iron Man War Machine Mark III Civil War
Looking for someone to assist in a Iron Man War Machine project. I have built a 3D printed War Machine and been trying to get the electronics going on this project. However I am somewhat limited and new to programming. Heres what I have made so far.
I am trying use the Arduino Uno + Music Maker Wav Shield (MP3 Sounds) and the Easy VR3 (pins 8/9) for the voice control. I also have a Pololu servo controller (haven't choose any pins for this to the Uno yet) which I plan to hook up via RX/TX to the Uno to control the servos for Shoulder Gun and arm guns (Guns will Pop up out of the gauntlet). I used the Easy VR commander to make my basic sketch for the commands. As a test, I was able to make some LEDs light up when I say Jarvis/Fire. This is about the max extent of my capabilities now.
So what I am planning to do is have 4 leds (2 on the shoulder gun 1 ea in the gun barrels and 1 LED on each of the arm gun barrels) total of 4 LEDs for guns. All gun LEDs are on pin 6. When I say "Shoulder" the servo on the pololu servo controller (pin 0 on the Pololu) will move and rise the shoulder gun. When I say "Fire" I want the MP3 file titled "gun.Mp3" to sound off (Mp3 File titled "Gun") and flash/strobe the LEDs (orange/redish color). When I say "Stop" the gun will stop firing. When I say "Safe" the guns servos will return the guns back into position" The Arm guns (pin 1 on the Pololu) will do the same and rise like the shoulder gun when I say "Arm". the return will command will also be "Safe"
The Unibeam will light up up and stay on when I say "You there" and a sound will play (Mp3 file is titled "jarvis.Mp3". 18 Neopixels on pin 10 for the unibeam (Redish Orange color). Leds will swipe on.
When I say "stand down" it will play a MP3 file from Col Rhodes titled "Standdown.Mp3" one time.
Any assistance you could provide I would be very grateful. I have popped a few brain vessels on this trying to get this started. Here's what I have so far from the EasyVR Commander. (Attached) If anyone is interested in helping I would be extremely grateful. I so what to have this project done and suit up. :slight_smile:
War.ino (11.8 KB)
Do you actually are capable of making an IronMan, Helmet!?(motorcycle rides!) if yes I can do development for free!
@NI$HANT-
No, these are not the same things. :slight_smile:
These are 3D printed (and possibly molded/cast afterwards)..
These are NOT true DOT approved motorcycle helmets..
@TKCC71
I can probably help as well.. the main issue I see is that I DO NOT have the VR set-up.. so I can really test that aspect of it..
