I tried using code from the GIT repository to create specific patterns in arrays, and I can't understand why it's not working as expected. For example, in this code, lines 1, 2, and 4 should be on, and 3 off, but it turns on 1, 2, and 3. I can't seem to find the issue; I would appreciate some help.
FastLED Mapping Demo: https://github.com/jasoncoon/led-mapper
Copyright (C) 2022 Jason Coon, Evil Genius Labs LLC
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <FastLED.h> // https://github.com/FastLED/FastLED
FASTLED_USING_NAMESPACE
// Based on FastLED "100-lines-of-code" demo reel, showing just a few
// of the kinds of animation patterns you can quickly and easily
// compose using FastLED.
// This example also shows one easy way to define multiple
// animations patterns and have them automatically rotate.
// -Mark Kriegsman, December 2014
#if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
// change these to match your data pin, LED type, and color order
#define DATA_PIN 0
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
#define BRIGHTNESS 32
// start of data copied from LED Mapper:
#define NUM_LEDS 48
byte coordsX[NUM_LEDS] = { 0, 17, 34, 51, 68, 85, 102, 119, 136, 153, 170, 187, 204, 221, 238, 255, 0, 17, 34, 51, 68, 85, 102, 119, 136, 153, 170, 187, 204, 221, 238, 255, 0, 17, 34, 51, 68, 85, 102, 119, 136, 153, 170, 187, 204, 221, 238, 255 };
byte coordsY[NUM_LEDS] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 85, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255 };
byte angles[NUM_LEDS] = { 10, 11, 13, 15, 19, 24, 32, 45, 64, 83, 96, 104, 109, 112, 114, 116, 5, 6, 7, 8, 10, 13, 19, 32, 64, 96, 109, 114, 118, 119, 121, 122, 250, 249, 248, 247, 245, 242, 236, 223, 191, 159, 146, 141, 137, 136, 134, 133 };
byte radii[NUM_LEDS] = { 255, 225, 196, 167, 138, 111, 87, 69, 62, 69, 87, 111, 138, 167, 196, 225, 249, 219, 188, 158, 128, 98, 69, 44, 31, 44, 69, 98, 128, 158, 188, 219, 249, 219, 188, 158, 128, 98, 69, 44, 31, 44, 69, 98, 128, 158, 188, 219 };
CRGB leds[NUM_LEDS];
#define FRAMES_PER_SECOND 120
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
uint8_t offset = 0; // rotating "base color" used by many of the patterns
uint8_t speed = 30;
boolean autoplay = true;
uint8_t autoplaySeconds = 2;
// delay(3000); // 3 second delay for recovery
// tell FastLED about the LED strip configuration
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setCorrection(TypicalSMD5050);
FastLED.setMaxPowerInVoltsAndMilliamps(5, 1000); // 1A
FastLED.setBrightness(BRIGHTNESS);
// List of patterns to cycle through. Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList patterns = {
// 2D map examples:
// clockwisePalette,
// counterClockwisePalette,
// outwardPalette,
// inwardPalette,
// northPalette,
// northEastPalette,
// eastPalette,
// southEastPalette,
// southPalette,
// southWestPalette,
// westPalette,
// northWestPalette,
// standard FastLED demo reel examples:
rainbow,
rainbowWithGlitter,
confetti,
sinelon,
juggle,
bpm
const uint8_t patternCount = ARRAY_SIZE(patterns);
uint8_t currentPatternIndex = 0; // Index number of which pattern is current
CRGBPalette16 IceColors_p = CRGBPalette16(CRGB::Black, CRGB::Blue, CRGB::Aqua, CRGB::White);
const CRGBPalette16 palettes[] = {
RainbowColors_p,
RainbowStripeColors_p,
CloudColors_p,
LavaColors_p,
OceanColors_p,
ForestColors_p,
PartyColors_p,
HeatColors_p,
IceColors_p,
const uint8_t paletteCount = ARRAY_SIZE(palettes);
uint8_t currentPaletteIndex = 0;
CRGBPalette16 currentPalette = palettes[currentPaletteIndex];
boolean autoplayPalettes = true;
uint8_t autoplayPaletteSeconds = autoplaySeconds * patternCount;
// Call the current pattern function once, updating the 'leds' array
patterns[currentPatternIndex]();
offset = beat8(speed);
// do some periodic updates
EVERY_N_SECONDS(autoplaySeconds)
if (autoplay)
nextPattern(); // change patterns periodically
EVERY_N_SECONDS(autoplayPaletteSeconds)
// change palettes periodically
if (autoplayPalettes)
nextPalette();
// send the 'leds' array out to the actual LED strip
// FastLED.show(); called automatically, internally by FastLED.delay below:
// insert a delay to keep the framerate modest
FastLED.delay(1000 / FRAMES_PER_SECOND);
void nextPattern()
// add one to the current pattern number, and wrap around at the end
currentPatternIndex = (currentPatternIndex + 1) % patternCount;
void nextPalette()
// add one to the current palette number, and wrap around at the end
currentPaletteIndex = (currentPaletteIndex + 1) % paletteCount;
// 2D map examples:
void clockwisePalette()
for (uint16_t i = 0; i < NUM_LEDS; i++)
leds[i] = ColorFromPalette(currentPalette, offset + angles[i]);
void counterClockwisePalette()
leds[i] = ColorFromPalette(currentPalette, offset - angles[i]);
void outwardPalette()
leds[i] = ColorFromPalette(currentPalette, offset - radii[i]);
void inwardPalette()
leds[i] = ColorFromPalette(currentPalette, offset + radii[i]);
void northPalette()
leds[i] = ColorFromPalette(currentPalette, offset - coordsY[i]);
void northEastPalette()
leds[i] = ColorFromPalette(currentPalette, offset - (coordsX[i] + coordsY[i]));
void eastPalette()
leds[i] = ColorFromPalette(currentPalette, offset - coordsX[i]);
void southEastPalette()
leds[i] = ColorFromPalette(currentPalette, offset - coordsX[i] + coordsY[i]);
void southPalette()
leds[i] = ColorFromPalette(currentPalette, offset + coordsY[i]);
void southWestPalette()
leds[i] = ColorFromPalette(currentPalette, offset + coordsX[i] + coordsY[i]);
void westPalette()
leds[i] = ColorFromPalette(currentPalette, offset + coordsX[i]);
void northWestPalette()
leds[i] = ColorFromPalette(currentPalette, offset + coordsX[i] - coordsY[i]);
void rainbow()
// FastLED's built-in rainbow generator
fill_rainbow(leds, NUM_LEDS, offset, 7);
void rainbowWithGlitter()
// built-in FastLED rainbow, plus some random sparkly glitter
rainbow();
addGlitter(80);
void addGlitter(fract8 chanceOfGlitter)
if (random8() < chanceOfGlitter)
leds[random16(NUM_LEDS)] += CRGB::White;
void confetti()
// random colored speckles that blink in and fade smoothly
fadeToBlackBy(leds, NUM_LEDS, 10);
int pos = random16(NUM_LEDS);
leds[pos] += CHSV(offset + random8(64), 200, 255);
void sinelon()
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy(leds, NUM_LEDS, 20);
int pos = beatsin16(13, 0, NUM_LEDS - 1);
leds[pos] += CHSV(offset, 255, 192);
void bpm()
// colored stripes pulsing at a defined Beats-Per-Minute (BPM)
uint8_t BeatsPerMinute = 62;
CRGBPalette16 palette = PartyColors_p;
uint8_t beat = beatsin8(BeatsPerMinute, 64, 255);
for (int i = 0; i < NUM_LEDS; i++)
{ // 9948
leds[i] = ColorFromPalette(palette, offset + (i * 2), beat - offset + (i * 10));
const byte dotCount = 3;
const byte hues = 240 / dotCount;
void juggle()
// eight colored dots, weaving in and out of sync with each other
for (int i = 0; i < dotCount; i++)
leds[beatsin16(i + 7, 0, NUM_LEDS - 1)] |= CHSV(i * hues, 200, 255);
