Hello. I been looking to resolve this problem for few days and I didn't find nothing helpful, only a lot of people asking same questions..
Basically I want to add ir remote to my arduino project. So I can control it with a remote controller. The problem is Im getting some random problems on this code and on any codes including IRremote. The code I post will receive ir signal and print the reading on serial port, so later I can use the readings in different part of my project.
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
And This is all the problems arduino IDE displays, I been downloading IRremote.cpp from different websites and the problem was the same, I been trying to change IRremote.cpp with a notepad as I found some people advising but nothing helped at all.
I belive someone on this www will know how to fix this up.
Thanks a lot for any help
Arduino: 1.5.5-r2 (Windows 8), Board: "Arduino Duemilanove or Diecimila, ATmega168"
In file included from C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:13:
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\/IRremoteInt.h:87: error: 'uint8_t' does not name a type
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\/IRremoteInt.h:88: error: 'uint8_t' does not name a type
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\/IRremoteInt.h:89: error: 'uint8_t' does not name a type
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\/IRremoteInt.h:92: error: 'uint8_t' does not name a type
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::mark(int)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:173: error: 'delayMicroseconds' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::space(int)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:181: error: 'delayMicroseconds' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::enableIROut(int)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:200: error: 'OUTPUT' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:200: error: 'pinMode' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:201: error: 'LOW' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:201: error: 'digitalWrite' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In constructor 'IRrecv::IRrecv(int)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:217: error: 'volatile struct irparams_t' has no member named 'recvpin'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:218: error: 'volatile struct irparams_t' has no member named 'blinkflag'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::enableIRIn()':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:241: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:242: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:246: error: 'volatile struct irparams_t' has no member named 'recvpin'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:246: error: 'INPUT' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:246: error: 'pinMode' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::blink13(int)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:252: error: 'volatile struct irparams_t' has no member named 'blinkflag'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:254: error: 'OUTPUT' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:254: error: 'pinMode' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In function 'void __vector_9()':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:268: error: 'volatile struct irparams_t' has no member named 'recvpin'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:268: error: 'digitalRead' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:271: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:273: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:275: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:284: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:285: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:287: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:293: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:295: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:300: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:302: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:310: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:321: error: 'volatile struct irparams_t' has no member named 'blinkflag'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:323: error: 'B00100000' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:326: error: 'B11011111' was not declared in this scope
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::resume()':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:332: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:333: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'int IRrecv::decode(decode_results*)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:343: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:344: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeNEC(decode_results*)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:392: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:400: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeSony(decode_results*)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:433: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:443: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeRC5(decode_results*)':
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:518: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Users\Kryku\Documents\Arduino\libraries\IRremote\IRremote.cpp:529: error: 'volatile struct irparams_t' has no member named 'rawlen'
enabled in File > Preferences.
