Is HC-06 a Bluetooth LE Device?
Hi All
I Tried to connect to HC-06 through android Bluetooth LE, But I failed at the begining.... I can not find HC-06 when I try to scan ...
So I am wondering if HC-06 is a normal bluetooth instead of Bluetooth LE, and they can not connect to each other?
Am I wrong?
Can anyone give me a explaination about this?
Hello and welcome,
Try with BlueTerm or SENA BTerm apps on your Android device. I have no idea if that will work, I don't have a Android device with BLE. It's possible that they are incompatible (BLE is theorically backward compatible but...)
HC-06 is not a BLE device but that shouldn't be the cause of your problem. If the led is flashing, the phone should be able to connect, but will communicate via BT2
guix:
Hello and welcome,
@guix blueterm works fine~~
Nick_Pyner:
Thank you for your answer.
The thing is,
I tried android official bluetooth le sample (http://developer.android.com/intl/zh-cn/samples/BluetoothLeGatt/index.html) without any modification, and it can not scan HC-06 out.
But I can scan it with blueterm
